Vieux 14/02/2022, 14h54
yazak
Avatar de yazak
yazak is an unknown quantity at this point
Bonjour a tous je viens vers vous j'ai un soucis avec un codage long ABS POLO 6 R de 2012 qui est totalement a 0000000000000.
merci d'avance.
Saturday,12,February,2022,16:4350725
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.12.0.0 (x64)
Data version: 20201124 DS322.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCY179878 License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCY179878 Mileage: 183050km-113741miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYB) Labels: None
Part No SW: 03L 906 023 MA HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 8849
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02013L906023MA 003004
ROD: N/A
VCID: 71E85ACBA06F3F0CFC-8024
No ASAM data for: "EV_ECM16TDI02013L906023MA" (VW25)
No fault code found.
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 000E0F0F97C5268403-8054
2 Faults Found
03306 - Coding Not Valid
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 187
Mileage: 183057 km
Time Indication: 0
Date: 2016.07.05
Time: 01:08:34
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1494
Hex Value: 0x0080
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 187
Mileage: 183057 km
Time Indication: 0
Date: 2016.07.05
Time: 01:08:34
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x1494
Hex Value: 0x0080
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 M HW: 6R0 820 045 M
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 387EA7EF8B95AE44FB-806C
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 011120988
Coding: 24B02BBF08A10000002008002D2B0CD00080410F6006000020 0000000000
Shop #: WSC 124697 483 00190
VCID: 4580DE1BCC67C3AC70-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200016701
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200015856
Coding: 08BC30
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX011V7KQ
Coding: 00314D
ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
ROD: N/A
VCID: 4A9AED27ED792CD49D-801E
Subsystem 1 - Serial number: 3575HRB406711PN8A1RG
Subsystem 2 - Serial number: 3585HRB406711PN8BPDS
Subsystem 3 - Serial number: 3515RRB404T11D48K9LL
Subsystem 4 - Serial number: 3525RRB404P11D48GP7G
No ASAM data for: "EV_AirbaVW10BPAWV250" (VW25)
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6R0 920 861 G HW: 6R0 920 861 G
Component: KOMBI H03 0505
Serial number: 00000000000000
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 3978A2EBB89FB74C04-806C
1 Fault Found
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 183057 km
Date: 2022.02.12
Time: 01:08:39
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002200
VCID: 70EE5FCFA3653604F3-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0505
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03009
ROD: N/A
VCID: 6ADA4DA78DB9CCD4BD-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6C9CB3EADB69FCAA-807A
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 56: Radio (J503) Labels: None
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio H42 0105
Revision: R0000000 Serial number: VWZAZ1L2059900
Coding: 0000020002
VCID: 2A5A8DA745390CD47D-807E
1 Fault Found
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 227
Mileage: 183065 km
Time Indication: 0
Date: 2016.07.07
Time: 00:19:28
End-------------------------(Elapsed Time: 02:01)--------------------------
yazak est déconnecté   Réponse avec citation
