Vieux 10/03/2022, 10h56
karimus
Avatar de karimus
karimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud ofkarimus has much to be proud of
Bonjour les amis,
Voici quelques infos dénichées sans les traduire en français pour ne pas perdre le vrai sens des phrases :
Prix : £510.00 (HT)
Alientech Kess 3 Hardware. The new kess3 tuning tools from Alientech. Kess 3 is an OBD and Bench tuning / Boot tuning and ecu remapping tool.
The super fast new Kess 3 is set to change tuning and remapping industry. With super fast ecu remapping processing. As well as flexible option for software and protocols. Is sure to make the new Alientech Kess 3 tuning tool the market leader.
This item, is the basic Alientech Kess 3 Hardware. The hardware is neither master or slave by definition when new. The Alientech Kess 3 Hardware unit is self can be assigned either master tuning or slave tuning and remapping protocols.
So the first step is to purchase the kess 3 hardware unit, and then select the protocols form the shop to complete the activation of your tuning tool
What protocols are available for the Alientech Kess 3?
One you have selected and purchased your Kess 3 unit. The next step its to select the protocols you want to activiate. In other words what vehicles do you want to offer remapping services on ? You can choose from:
Bike, ATV, and UTV
Cars, vans and light commercials
Agricultural and Trucks
Marines and water craft
The above protocols / tool activations are available both as master or slave versions.
OBD tuning or Boot / Bench tuning
As the Kess3 is available as either an OBD tuning tool, Bench tuning and remapping tool, or both. Each of the above Kess 3 protocol activations are available for either OBD, or Bench. Or of course select both option to be able to active your tuning tool for both methods of tuning and remapping.
Slts.
le savoir se cultive par le partage
karimus est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to karimus For This Useful Post:
Fastdiag (10/03/2022), pp08 (10/03/2022), willy14 (10/03/2022), xdols (10/03/2022), yann3 (30/03/2022)
