Vieux 26/03/2022, 12h23
OVERSPEED
Avatar de OVERSPEED
Pouvoir de réputation: 91
Ok , mais normalement les lignes de données sont independantes du 24 V ou du 12 V alim
Pin Signal Description
2 J1850 Bus+
4 CGND GND
5 SGND GND
6 CAN High J-2284
7 ISO 9141-2 K-LINE Tx/Rx
10 J1850 Bus-
14 CAN Low J-2284
15 ISO 9141-2 L-LINE Tx/Rx
16 +12v Battery power
SAE J1850 PWM (41.6 kbaud, standard of the Ford Motor Company)
pin 2: Bus-
pin 10: Bus+
High voltage is +5V
Message length is restricted to 12 bytes, including CRC
Employs a multi-master arbitration scheme called
"Carrier Sense Multiple Access with Non-Destructive Arbitration" (CSMA/NDA)
SAE J1850 VPW (Variable Pulse Width) (10.4/41.6 kbaud, standard of General Motors)
pin 2: Bus+
Bus idles low
High voltage is +7V
Decision point is +3.5V
Message length is restricted to 12 bytes, including CRC Employs CSMA/NDA
ISO 9141-2. This protocol has a data rate of 10.4 kbaud, and is similar to RS-232.
ISO 9141-2 is primarily used in Chrysler, European, and Asian vehicles.
pin 7: K-line
pin 15: L-line (optional)
UART signaling (though not RS-232 voltage levels)
K-line idles high
High voltage is Vbatt
ISO 14230 KWP2000 (Keyword Protocol 2000) used by most European and Asian manufacturers.
Alfa Romeo, Audi, BMW, Citroen, Fiat, Honda, Hyundai, Jaguar (X300, XK), Jeep since 2004,
Kia, Land Rover, Mazda, Mercedes, Mitsubishi, Nissan, Peugeot, Renault, Saab, Skoda,
Subaru, Toyota, Vauxhall, Volkswagen (VW) since 2001, Volvo to 2004
pin 7: K-line
Physical layer identical to ISO 9141-2
Data rate 1.2 to 10.4 kbaud
Message may contain up to 255 bytes in the data field
ISO 15765 CAN (250kbit/sec or 500kbit/sec)
pin 6: CAN High
pin 14: CAN Low
mais je suis ouvert á la discussion , il y a toujours a apprendre
Au revoir
OS
The Following 3 Users Say Thank You to OVERSPEED For This Useful Post:
ElTurco (28/03/2022), MecaTech (26/03/2022), zazear (27/03/2022)
