03/06/2022, 08h06
Pouvoir de réputation: 40
VAG DPF 3.26.11 Full (for Android device + ELM37)
With this application you can find out if the filter is really in the process of regeneration, if the regeneration is awaiting completion, how many kilometers have you traveled since the last regeneration, etc.
Core functions: - Display of 12 DPF filter parameters like soot mass accumulation in the filter, regeneration duration, km traveled and time passed since last regeneration, EGR valve closing, exhaust gas temperatures of the inlet, and outlet of DPF (Attention: data shown may vary depending on the engine type due to the presence of the parameters into the engine ECU)
- Manual or automatic parameters update
- Display, for all the parameters, of the previous value and the difference between the ****** and the previous value (only for automatic update delays different from 0 seconds)
- Ability to exclude one or more parameter to increase the reading speed
- Display of the filter filling percentage before reaching the filling limit that starts the execution of a field regeneration (standard regeneration controlled by the engine ECU)
- Graphical display, using a progress bar, of the filling percentage value before starting a field regeneration or a service regeneration
- Graphical display of the filter status: red filter for the regeneration phase (passive, field, or service) of the grey filter with different back internal areas depending on the filling percentage value
- Display of extra data: adapter communication error counter, filter filling rating in µg/min, update time of all the 12 parameters, automatic update delay ******ly selected in the options menu
- Notification bar icon to show an active connection and the auto-update process running.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
