Discussion: C5 ne démarre pas
Vieux 31/12/2012, 18h49
nimbus
Avatar de nimbus
Pouvoir de réputation: 73
nimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond repute
je doute sur ta pp hp car mm hs la pression monte faiblement mais pas 0
d'ailleurs a l'arret au diag tu devrais avoir au moins 5 bars regarde ton capteur rail
ds t parametre a tu toutes les valeurs syncro arbre cames pmh ok?cote distri pp hp bien entrainer?
nimbus est déconnecté   Réponse avec citation
The Following User Says Thank You to nimbus For This Useful Post:
MecaTech (12/10/2013)
