Vieux 06/07/2022, 16h34
OVERSPEED
Avatar de OVERSPEED
Pouvoir de réputation: 91
Par défaut VIDA pas d affichage module com croix rouge J2534
En cas de non affichage module communication ( DICE ou J2534 ) la solution pour windows 7 64.
Hold windows key + R. Type regedit.
Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\M icrosoft\.NETFramework
Once the window open
There click on the .NETFramework file and you will see 2 values (Default) and InstallRoot. There should be a 3rd value.
Right click .NetFramework
than go to new and down to DWord (32bit) and click it.
Name the new one "EnableIEHosting" without the quotations.
Than right click the item you just renamed and click modify.
In the value type "00000001" without quotations. Should be seven 0s and a 1.
Click ok.
Fermer la page regedit
Relaunch the webpage login and you should be able to pick your tool.
Attention decimal / hexa
Au revoir
OS
The Following 3 Users Say Thank You to OVERSPEED For This Useful Post:
caroptimum (07/07/2022), Guidel37 (30/06/2023), MecaTech (06/07/2022)
