18/07/2022, 14h29
Pouvoir de réputation: 46
KIA Gen 2.0 Software + Map 2021
Supported cars: - Picanto (TA)
- Rio (UB)
- Venga (YN)
- Optima (JF)
- New Sportage (QL)
- New Sorento (UM)
- Ceed (JD) MY15-16.
Instruction how to update: - Delete all from SD card
- Copy to root of sd card software
- Insert SD card in the car
- Do not start the engine or touch the gearbox
- How will the proposal for "Download Software" click the update button
- In the "Caution" window, click the Accept button
- Wait about 10-15 minutes, during the upgrade there, will be three stages (system software, firmware, navigation)
- Reset to factory settings. You can skip this action and then do as you wish
- After up****** the system, remove the SD card, delete everything from it and copy the entire contents of the archive with the cards to the root of the SD card
- Insert the SD card into the car and enjoy life.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
