Discussion: Rapport erreurs vcds
Vieux 22/07/2022, 11h30
boris93600
Avatar de boris93600
Problème d'alim.
Efface les DTC et refait un scan direct .
Utilise les balises "code" bouton "#" quand tu inserts le rapport dans ton message :
Code:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ3CZAP055312 License Plate:
Mileage: 243570km-151347mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
72
VIN: WVWZZZ3CZAP055312 Mileage: 243570km-151347miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 GL HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9972
Revision: --H23--- Serial number: VWZCZ000000000
Coding: 00114036032401080000
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_ECM16TDI02103L906023GL 003013
ROD: EV_ECM16TDI02103L906023GL_003.rod
VCID: 76E43D9AC95C7DF1C3-8022
10 Faults Found:
7329 - Mass Air Flow Sensor (G70)
P0101 00 [104] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 94
Mileage: 241288 km
Date: 2022.07.22
Time: 17:19:53
Engine speed: 1997.75 /min
Normed load value: 0.0 %
Vehicle speed: 54 km/h
Coolant temperature: 99 °C
Intake air temperature: 41 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.553 V
Unlearning counter according OBD: 40
Air mass: ****** value (mg/stroke)-MAF_MES: 346.45 mg/stroke
Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 1.23651
EGR solenoid valve: ****** value-ANG_EGRV[0]: 0.000 %
Throttle valve adapter: ****** value-ANG_THR[0]: 95.868 %
Charge air pressure specified value-MAP_SP_MMV: 1139.45 hPa
Charge air pressure: ****** value-MAP_MMV: 1139.45 hPa
Engine torque-TQI_SP: 0.00 Nm
7391 - Fuel Pump Relay Control Circuit
P0628 00 [032] - Short to Ground
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0036
Engine speed: 0.00 /min
Vehicle speed: 0 km/h
Coolant temperature: 63 °C
Intake air temperature: 39 °C
Voltage terminal 30: 11.972 V
Unlearning counter according OBD: 11
Engine speed: 0 /min
Battery voltage: 12.0 V
Fuel high pressure: ****** value-FUP_FIL: 0.000 MPa
Fuel Metering Valve-VCV: 0.000 %
Fuel Pressure Regulator Valve-PCV: 0.000 %
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 48 °C
6068 - No Communication with Instrument Cluster
U0155 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
7430 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
6082 - Steering Column Control Module
U0212 00 [032] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
10231 - Valve for Fuel Metering (N290)
P0090 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0003
Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.076 A
Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
10113 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0003
Fuel pressure regulator valve ****** value-CFB_PCV_MES: 0.076 A
Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV: 3.2877 V
9875 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0047 00 [032] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 0028
Voltage terminal 30: 12.085 V
Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: 10.626 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
High press turbocharger actuator: ****** uncond volt value-V_BPA[0]: 0.674 V
Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
Turbocharger boost control: offset -V_BPA_TOL[0]: 3.330 V
Charge air pressure: ****** value-MAP_MMV: 200.00 hPa
Sensor for temp after charge air cooler: raw value-TBA_MES: 39 °C
10123 - ECM Power Relay Control Circuit
P0685 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 242849 km
Date: 2022.07.22
Time: 00:19:13
Voltage terminal 30: 0.000 V
Battery voltage: 0.0 V
Voltage terminal 15-V_IGK: 12.1 V
Starter control: Start interruption status-Binary 16 Bit: 00011001 00000000
Fuel pressure regulator valve ****** value-CFB_PCV_MES: 0.067 A
Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.057 A
Readiness: 1100 0000
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AK HW: 3C0 614 109 AK
Component: J104 C4 440 V2 0027
Revision: --025--- Serial number: 00000705619431
Coding: 0035311
Shop #: WSC 00028 790 00002
VCID: 67DA60DE56F6947948-8032
8 Faults Found:
00576 - Terminal 15
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:30:15
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00111110
Count: 123
Hex Value: 0x0000
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:30:15
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:34:52
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:34:52
01200 - ABS Valves Supply Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0020
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 3.00 V
Bin. Bits: 00011111
Count: 64
Hex Value: 0x0000
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0020
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 192
Hex Value: 0x0000
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000003
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7DF622B6EC6A2EA982-8028
3 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0055
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Date: 2022.07.22
Time: 1856
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB
Component: Bordnetz-SG H57 3204
Revision: 00H57000 Serial number: 00000003798256
Coding: E1900F0700041A00470A00000F00000000015D435C00012000 0308000000
Shop #: WSC 00028 028 00001
VCID: 71EE0E8668325AC916-FFFE
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 270410 006 0208
Coding: 00046997
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 140510 054 0403
Coding: 00208936
Shop #: WSC 00028
10 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1801
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
ON
OFF
OFF
00906 - Horn (H1)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1801
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0001
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
ON
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0001
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0001
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
ON
OFF
OFF
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0001
00059 - Terminal 30 for Interior Lighting
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 000
00926 - Terminal 30
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08791012036875
Coding: 100002
VCID: 326CC18A6DB421D12F-8066
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Freeze Frame:
Temperature: 31.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1857
Freeze Frame:
Temperature: 32.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1857
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__005 VW10 HI 1916
Revision: 21014000 Serial number: 003GHP9C1YH5
Coding: 0012341
Shop #: WSC 01383 790 00002
VCID: 489883623B28BB0161-801C
Subsystem 1 - Serial number: 6332MTS615421100
Subsystem 2 - Serial number: 6342MTS647871100
Subsystem 3 - Serial number: 6351HTS6AA0UA6KR
Subsystem 4 - Serial number: 6361HTS619VTA6KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1857
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242551 km
Time Indication: 0
Date: 2016.12.12
Time: 07:08:24
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100514200078
Coding: 0182270002
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 72EC018AA53461D1EF-8026
6 Faults Found:
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 0 km
Date: 2000.01.01
Time: 00:00:00
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 0 km
Date: 2000.01.01
Time: 00:00:00
227355 - Windshield Wiper/Washer Switch
B1149 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 0 km
Date: 2000.01.01
Time: 00:00:00
332564 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
332660 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 242551 km
Date: 2022.07.22
Time: 07:08:23
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 872 G HW: 3C0 920 872 G
Component: KOMBI H03 0305
Coding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 295E26E6486262099E-807C
7 Faults Found:
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0055
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Date: 2022.07.22
Time: 18:34:52
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 111
Mileage: 243260 km
Date: 2022.07.22
Time: 1740
12666368 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 N HW: 3C0 907 951
Component: J533 Gateway H14 0172
Revision: H14 Serial number: 1021G104280283
Coding: F9A07F06400203041002
VCID: 2C50DFF28F90772165-8078
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:34:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1857
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1857
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 7AFC29AA35441991A7-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
1 Fault Found:
02828 - Enabling Steering Column Lock from Diagnostic Interface
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 1815
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0305
Revision: 12101005 Serial number: 0000871874
Coding: 0210B7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 26442DDA597C4D71B3-8072
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0402
Serial number: 00000001461478
Coding: 000090
7 Faults Found:
66561 - Motor for mirror fold-in
B11F6 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 132
Mileage: 201184 km
Date: 2021.05.30
Time: 18:02:44
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Reset counter: 113
Mileage: 201144 km
Date: 2021.05.29
Time: 1630
68102 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Date: 2022.07.22
Time: 1856
68103 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 104
Mileage: 242848 km
Date: 2022.07.22
Time: 18:34:52
68108 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0055
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 242859 km
Date: 2022.07.22
Time: 18:54:31
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.147 0703
Revision: 1AH03726 Serial number: 00101230108101
Coding: 0000258
VCID: 3A7CE9AA75C4D991E7-806E
6 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:30:42
Freeze Frame:
Term 15 Off
RPM: 0 /min
Speed: 0.0 km/h
(no units): 12.0
Voltage: 12.30 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:30:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0056
Freeze Frame:
Term 15 On
RPM: 1500 /min
Speed: 0.0 km/h
(no units): 4.0
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0056
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 4.0
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Coding: 00910A0001860E763004941570084F0B607C01
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 104
Mileage: 242848 km
Time Indication: 0
Date: 2016.12.12
Time: 18:34:53
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Component: EZE_2 H14 0172
Revision: -------- Serial number: 1021G104280283
Coding: 00000000
VCID: 66C46DDA91FC8D7173-8032
No fault code found.
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
Component: TUER-SG BT 002 0305
Revision: 14101005 Serial number: 0000864696
Coding: 0210B6
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 275A20DE5E76547988-8072
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0402
Serial number: 00000001459122
Coding: 000090
7 Faults Found:
66562 - Heated Exterior Mirror
B11F8 14 [008] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 99
Mileage: 241624 km
Date: 2022.07.22
Time: 12:49:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 228
Reset counter: 208
Mileage: 201144 km
Date: 2021.05.29
Time: 1630
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242848 km
Date: 2022.07.22
Time: 1856
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0023
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 104
Mileage: 242848 km
Date: 2022.07.22
Time: 18:34:52
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 104
Mileage: 242849 km
Date: 2022.07.22
Time: 0055
131072 - Rear Door Control Module
B11ED 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 199316 km
Date: 2021.04.13
Time: 1542
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000274620
Coding: 0000056
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
Freeze Frame:
Voltage: 11.80 V
Count: 36
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 0024
03182 - Clutch Position Sensor (G476)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 00:03:45
Freeze Frame:
Voltage: 11.90 V
Count: 57
Speed: 0.0 km/h
Hex Value: 0x1261
Hex Value: 0x0001
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 104
Mileage: 242849 km
Time Indication: 0
Date: 2016.12.12
Time: 00:03:45
02442 - Function Lamp in Control Head
Freeze Frame:
Fault Priority: 2
Reset counter: 133
Mileage: 225602 km
Time Indication: 0
Date: 2016.12.12
Time: 0809
Freeze Frame:
Voltage: 12.50 V
Count: 81
Speed: 0.0 km/h
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0202
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 3C0 907 951
Component: Batt.regelung H14 0172
Coding: 030B085A
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790121372
End-------------------------(Elapsed Time: 02:40)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 10: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
