voici le résultat du test
UPA-USB Device Programmer v12113
Licensed to: Kadir Kaleli
System: Microsoft Windows 7 Professional Service Pack 1 (build7601), 64-bit
Detecting UUSP...Pease wailt!
Device Description: ELRASOFT UPA-USB3.0 Driver (1.2.2.00, 12/20/2012)
USB Driver Name: UPAUSB.sys, HS Mode
5V Tests. Close J1 and press a key to continue
Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=7,94V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,04V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,93V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,80V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=11,89V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=12,79V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=4,00V (L), P3=0,00V (L), P4=0,00V (L),P6=4,17V (L), P7=0,00V (L), P8=0,00V (L), P9=5,04V
P6(4,17V ) not in 3,00V - 4,00V
Test Failed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=5,04V
Test Passed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,98V (H), P3=5,09V (H), P4=5,09V (H),P6=5,20V (H), P7=5,09V (H), P8=5,06V (H), P9=5,04V
Test Passed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=3,05V (H), P3=0,00V (H), P4=0,00V (H),P6=3,16V (H), P7=0,00V (H), P8=0,00V (H), P9=3,63V
Test Passed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=3,61V
Test Passed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=3,58V (H), P3=3,66V (H), P4=3,66V (H),P6=3,74V (H), P7=3,66V (H), P8=3,64V (H), P9=3,61V
P6(3,74V ) not in 3,00V - 3,70V
Test Failed
Test60
9544961E87D538A3
Test Passed
2 Tests failed
