Vieux 15/09/2022, 15h55
boris93600
Avatar de boris93600
Voici les caractéristiques (PRcode) de ta Leon :
https://mega.nz/file/45NFBTgD#sK3aPz...loixZvVa8OJxt8
Voici un codage du web (même Leon que la tienne):
Code:
Thursday,22,August,2019,12:43:29:23287
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ5FZFR009388   License Plate:
Mileage: 136250km-84661mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZFR009388   Mileage: 136250km-84661miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRVC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EC    HW: 04L 907 309 C
   Component: R4 2,0L EDC   H22 6790
   Revision: 82H22---
   Coding: 01190112032400010000
   Shop #: WSC 00049 770 00123
   ASAM Dataset: EV_ECM20TDI01104L906021EC 002006
   ROD: EV_ECM20TDI01104L906021EC.rod
   VCID: 6A8DC0A0ACFA462774D-803E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 61364000003879
   Coding: 20EE629224200975007A060841CB240446249000608224B200610030C002
   Shop #: WSC 00049 770 00107
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_SE37.rod
   VCID: 44D14E18EE1E7057AE1-8010
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00000114200100010001000000001000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   VCID: 270BF9947F68BB4FAB3-8072
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011413602946
   Coding: 08100A424041027B4BE44000400403201000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00598208BA86AC77CA9-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140505  041 0574
   Serial number:         140507183043
   Coding: 0BC5FD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M05D15H15M02S42
   Coding: 00095D
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS72.023  H02 0007
   Serial number:     WOO29553716
   Coding: 180102
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 94231414703794
   Coding: 0031151001
   ASAM Dataset: EV_EPHVA18AU3700000 002024
   ROD: EV_EPHVA18AU3700000_002_VW37.rod
   VCID: 3D273BFC8DF4019FE1F-8068
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PA1YPPN
   Coding: 98CCC000000000005C0000CC000800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B01F4C778D38FB33-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 405 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U0000008C878CF0Z
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 405 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U00000076D6C7F0W
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 905 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R5F2FA503000000B
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 905 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R0AFDA403000000C
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 304 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556VD3E261030000006
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 29051404220125
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 77ABE9D4EF48EBCFFB3-8022
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5F0 920 862 A    HW: 5F0 920 862 A
   Component: KOMBI         202 4270
   Coding: 07A502002980000800082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002080257
   Coding: 010100E000087300EF000288080F00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DD4800F40A7E679CD-8016
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A0316080514
   Coding: 002000
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000103333671
   Coding: 00100320DE00040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000002651344
   Coding: 310000
1 Fault Found:
65648 - Controls for Window Regulator; Driver Side
          B1315 29 [009] - Signal Implausible
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 136250 km
                    Date: 2019.08.22
                    Time: 01:05:42
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8102
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF470CF10C657F857-8014
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000103145332
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 43D34D04EB10776F97B-8016
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000002733880
   Coding: 290000
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 040A000009000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB.rod
   VCID: 75B7E3DCF54499DFE9F-8020
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 5F0 035 824 A    HW: 5F0 035 824 A
   Component: MU-S--ER      040 0425
   Serial number: E1E02605142761
   Coding: 04730000FF0A000021110001001800002F0101140100010002
   ASAM Dataset: EV_MUStd6C3PASE 002029
   ROD: EV_MUStd6C3PASE.rod
   VCID: 221DE880144A5E67FCD-8076
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5F0 919 603     HW: 5F0 919 603
   Component: ABTmin_Std_Rd  H60 0030
   Serial number: SEZ8Z9PT8001MB
End----------(Elapsed Time: 00:59, VBatt start/end: 12.3V/12.3V)-----------
Avec les infos correspondantes :
https://mega.nz/file/kttzgRCA#g43i5j...CHzEE7lqKMakTw
Avec le document de Zenata, fais les modif pour le VIN....
zenata (15/09/2022)
