Vieux 30/09/2022, 13h35
ebt255
Avatar de ebt255
ebt255 has a spectacular aura aboutebt255 has a spectacular aura aboutebt255 has a spectacular aura about
Thanks toi havé accès to pdx files ?
---------- Post added at 10h03 ---------- Previous post was at 10h01 ----------
Need one for MD1CS016 ecu
Unfortunately no, the access to the reprog files (KWP - old) (PDX - new) is strongly secured.
Envoyé par ALBALOCHI Voir le message
I saw that you had already had this experience, how you could reprogram your ecu TDB ?
Regards,
To do a reprog you can try Clip + Token and enter a different VIN, that trick worked with the old modules.
To do reprog with any reprog file you will need DDT and special access to Renault servers or AES encryption key needed to unlock SA. With the AES key, you can reprog offline over DDT with any reprog file. I have several AES keys, but I do not have one for the TDB Clio 5.
ebt255 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to ebt255 For This Useful Post:
ALBALOCHI (30/09/2022), fils (30/09/2022), Xabi06 (07/10/2022)
