Vieux 30/09/2022, 14h22
ALBALOCHI
Banned
Avatar de ALBALOCHI
ALBALOCHI will become famous soon enoughALBALOCHI will become famous soon enough
Envoyé par ebt255 Voir le message
Unfortunately no, the access to the reprog files (KWP - old) (PDX - new) is strongly secured.
To do a reprog you can try Clip + Token and enter a different VIN, that trick worked with the old modules.
To do reprog with any reprog file you will need DDT and special access to Renault servers or AES encryption key needed to unlock SA. With the AES key, you can reprog offline over DDT with any reprog file. I have several AES keys, but I do not have one for the TDB Clio 5.
I already tried with the clip, but the reprogrammation is failing on 93% and getting error "The files are not matchd"
My unit its patched on SAcces but is virgin no maps file, yes difficult to found this pdx.
Thanks for your help
if you have a vergion unit, it's much more easier to passe Auto-Configuration by Clip.
in my case I'm trying to change the base program, which clip can't do it.
ALBALOCHI est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to ALBALOCHI For This Useful Post:
Farouq (07/10/2022), Xabi06 (07/10/2022)
