Vieux 03/10/2022, 09h37
33300
Avatar de 33300
33300 is an unknown quantity at this point
Patch rtl clone Board
c:\CLIP\Config\
probesConfiguration.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<!-- Keywords PVCS : Begin -->
<!--?DoC_Info Revision="$Revision:   1.8  $" Author="$Author:   acarref  $" Date="$Date:   Dec 13 2005 18:58:24" ?-->
<!-- Keywords PVCS : end -->
<Conf_Root>
	<Conf_Set name="Borneo">
		<Conf_Set name="Acquisition" doc="Acquisition layer configuration, see NT021027.001">
			<Conf_Param name="DriverPath" value="../Drivers"/>
			<Conf_Param name="DriverIniPath" value="../../../CLIP/Data/Appli/Params/"/>
			<Conf_Param name="FirmwarePath" value="../../../CLIP/Data/Appli/Params/"/>
			<Conf_Param name="ProbesInfoPath" value="../../../CLIP/Data/User/probesInformation.xml"/>
			<Conf_Set name="Boards">
				<!-- BoardNis04VI -->
				<Conf_Set name="BoardNis04VI">
					<Conf_Param name="DriverFile" value="Nis04_VI_DrvUsr.dll"/>
					<Conf_Param name="DriverIniFile" value="VIDrvUsr.ini"/>
					<Conf_Param name="AppliFirmwareFile" value="NISVI04_firmware.s28"/>
					<Conf_Param name="BootFirmwareFile" value="BOOTNISVI04.s28"/>
					<Conf_Param name="BTFirmwareFile" value="UnspecifiedAsFirmwaresAreNeverUpdated.dfx"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoardNis04VIAdapter"/>
					<Conf_Param name="ProtocolesServicesFile" value="../../Data/Appli/Params/AcqProtocolServices.xml"/>
					<Conf_Param name="EnumTimeout" value="180" dmtype="int"/>
					<!--Conf_Param name="PortKwpProtocolName" value="PR2003_0.AP" dmtype="string"/-->
					<!-- uncomment this line to executre PR2003_0 in native mode -->
					<Conf_Param name="PortKwpProtocolName" value="PR2000_R.AP"/>
					<Conf_Param name="PortDdl1ProtocolName" value="PRDDL1V2.AP"/>
					<Conf_Param name="EnumPriority" value="1" dmtype="int"/>
				</Conf_Set>
				<!-- Board16 -->
				<Conf_Set name="Board16">
					<Conf_Param name="DriverFile" value="JcaeCan.dll"/>
					<Conf_Param name="DriverIniFile" value="JCAECanIso.ini"/>
					<Conf_Param name="FirmwareFile" value="Applican.s19"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoard16Adapter"/>
					<Conf_Param name="BusyRetry" value="60"/>
					<Conf_Param name="EnumPriority" value="2" dmtype="int"/>
				</Conf_Set>
				<!-- Board17 -->
				<Conf_Set name="Board17">
					<Conf_Param name="DriverFile" value="JcaeIso.dll"/>
					<Conf_Param name="FirmwareFile" value="Appliiso.s19"/>
					<Conf_Param name="Adapter" value="borneo:/AcqBoard17Adapter"/>
				</Conf_Set>
				<!-- BoardJ2534 -->
				<Conf_Set name="BoardJ2534">
					<Conf_Param name="Adapter" value="borneo:/AcqBoardJ2534Adapter"/>
					<Conf_Param name="APIVersion" value="04.04"/>
					<Conf_Param name="EnumPriority" value="3" dmtype="int"/>
				</Conf_Set>
			</Conf_Set>
			<!--  Tm089755 Firwmare update: only X91 performs it (it is overriden in that application's config file) -->
			<Conf_Param name="FwUpdateBehavior" dmtype="int" value="4" type="integer" min="1" max="4" doc="{UpdateAlways=1;UpdateIfDifferent=2;UpdateIfLower=3;UpdateNever=4}. UpdateIfLower recommanded."/>
			<!-- Acq internals, insignificant impact if changed -->
			<Conf_Param name="ReadingLoopDelay" value="50" doc="the thread reading messages from the driver wakes up every 'ReadingLoopDelay' to ensure application does not want to exit"/>
			<Conf_Param name="OverloadWarningLevel" value="200" doc="a warning message is logged if the ECU answer buffer contains more than 'OverloadWarningLevel' messages"/>
		</Conf_Set>
		<!-- Acquisition -->
	</Conf_Set>
</Conf_Root>
probesConfiguration.logs
Code:
<?xml version="1.0" encoding="UTF-8"?>
<Conf_Root>
					<Conf_Param name="DriverFile" value="JcaeCan_avec_log.dll"/>
					<Conf_Param name="DriverIniFile" value="JCAECanIso_logs.ini"/>
				</Conf_Set>
				<!-- Board16 -->
					<Conf_Param name="DriverFile" value="JcaeIso_avec_log.dll"/>
				</Conf_Set>
				<!-- Board17 -->
					<Conf_Param name="DriverFile" value="Nis04_VI_DrvUsr_avec_log.dll"/>
					<Conf_Param name="DriverIniFile" value="VIDrvUsr_logs.ini"/>
				</Conf_Set>
					<!-- no provisions for logs exist in current version, maybe it will have to be added here in the future -->
				</Conf_Set>
			</Conf_Set>
		</Conf_Set>
	</Conf_Set>
</Conf_Root>
Type de fichier : zip CLIP.zip (5,6 Ko, 106 affichages)
33300 est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to 33300 For This Useful Post:
bzkmatrix (16/11/2023), kevin22 (01/11/2022), khalil84 (27/11/2022), mohaalba (03/10/2022), sachscott (15/04/2024), youcef_trik (12/05/2024)
