Vieux 12/01/2013, 21h26
formator2
Avatar de formator2
formator2 is a jewel in the roughformator2 is a jewel in the roughformator2 is a jewel in the roughformator2 is a jewel in the rough
01315 - Transmission Control Module
01315 - Transmission Control Module: No Communications
Possible Causes
* CAN-Databus Wiring/Connectors from/to Transmission Control Module faulty
* Fault(s) stored in Transmission Control Module
Possible Solutions
* Check CAN-Databus Wiring/Connectors from/to Transmission Control Module
* Check Measuring Value Blocks (MVB)
o Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01315 - Transmission Control Module: Check DTC Memory
Possible Causes
Possible Solutions
* Check Transmission Control Module for Fault Codes
Special Notes
* Transmission Control Module stored a Code which influences other Control Modules Functionality
jedes Problem hat eine Lösung.
formator2 est déconnecté   Réponse avec citation
