Vieux 12/01/2013, 21h32
jruibarroso
Avatar de jruibarroso
jruibarroso is an unknown quantity at this point
Audi A4 (8E) Comfort System
Contents [hide]
1 Coding
2 Adaptation
2.1 Channel 000: Remote Control Clearing
2.2 Channel 021: Remote Control Matching
2.3 Channel 061: Variant Reduction
2.4 Channel 062: Comfort Functions
3 Special Procedures
3.1 Remote Control Synchronization
4 Special Notes
5 Video Link
Coding
+00001 = GB-Alarm (not USA)
+00002 = Confirmation Anti-Theft Warning System (Blink)
+00004 = Selective Central Locking (SCL)
+00008 = Anti-Theft Warning System
+00016 = Rear Lid Release Locking at 5 km/h
+00032 = Central Locking at 15 km/h (or 10 mph)
+00064 = Comfort Function via Remote Control (not USA)
+00128 = Right Hand Drive (RHD)
+00256 = Avant
+00512 = Confirmation Close via Remote (1x Blink)
+01024 = Confirmation Anti-Theft Warning System Horn Activation
+02048 = Door-/Window Regulator Logic
+04096 = Thatcham Anti-Theft Warning (not USA)
+08192 = No Safe-Function
+16384 = Side Windows with Insulated Glass
Note: Coding is the sum of the individual options. Not all options apply for all control modules!
Adaptation
This Adaptation Channel is used to clear all matched Remote Controls. This is often necessary prior to matching new remotes.
[Select]
[46 - Central Convenience]
[Adaptation - 10]
Channel 021.
[Read]
Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory position 3). Make sure to TYPE IN the number instead of scrolling up to it, otherwise you will not be able to click [Test].
[Test]
Now press any button on the remote you want to match.
The meas. block field above will change from Not Recogn. to Recognized.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Notes: You can check the current memory positions using Meas. Block 007. If remotes are recognized but not functional see the Remote Control Synchronization procedure and Special Notes .
jruibarroso est déconnecté   Réponse avec citation
