Discussion: Ethanol jaguar s-type
Vieux 11/10/2022, 13h14
jpay2
Avatar de jpay2
jpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant futurejpay2 has a brilliant future
Envoyé par OVERSPEED Voir le message
Trouvé sur le net , la Taurus est equipée du meme moteur
The 1998 Ford Taurus is available with an optional 3.0 liter, V6
engine capable of operating on E85 (85% ethanol and 15% gasoline),
unleaded gasoline, or any blend of the two. Ford has offered
an E85 Taurus in its AFV lineup since 1994. These flexible-fuel
vehicles (FFVs) give the driver the convenience of fueling with
gasoline where E85 is not available. A sensor monitors the fuel
composition and sends the information to the on-board computer,
which automatically adjusts the air-fuel ratio to optimize its
performance on the current mix of fuel. The estimated driving
range for the FFV Taurus operating on E85 is 250–340 miles,
and on gasoline it is 340–470 miles. Several design changes were
necessary to allow for operation on alcohol fuels. These changes
include a unique block material, exhaust valve seat inserts, wearresistant
rings, alcohol-compatible fuel injectors specially designed
for high flows, increased volume evaporative canister, a stainless
steel fuel system, and unique engine calibration for ethanol
operation.
Au revoir
OS
bonjour,
tres interessant de voir un constructeur qui prevoit cette utilisatin (en option si j'ai bien lu.....) et cela revele bien ce que je pense concernant l'ethanol, (essence vegetal donc agression chimique x, comparer a l'essence mineral 95/98 issu du petrol , ils n'ont pas changer que la cartho ......
bref interressant
dans tonc cas pour cette ford, il te faut (si j'ai bien lu ...) controler avoir le motage de controle d'essence (boitier analiseur d'essence sur la ligne reservoir/moteur )
si tu l'as, oui tu peut en mettre , si tu l'as pas .....elle n'est pas prevut
comme a chaque cas, meme moteur , tous pareils, oui enfin presque, et les differences sont mathematiquement indispensable
a+
jpay2 est déconnecté   Réponse avec citation
The Following User Says Thank You to jpay2 For This Useful Post:
pp08 (11/10/2022)
