Discussion: Code pin bsi C3
Vieux 11/11/2022, 10h27
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
bonjour a tous les membres
voila je vais vous repondre a votre question
la cle est d origine avec telecomande
j ai utilise une pcf7936
l outil utilise pps
quand je fais l apprentissage des cles le code est correcte mais apres echec de programation
je vais essayer de verifier la bobine
si c est possible le schema de cablage de la bobine jusqu au bsi et merci
l union fait la force
electro_bordeaux1 est déconnecté   Réponse avec citation
The Following User Says Thank You to electro_bordeaux1 For This Useful Post:
phil1 (11/11/2022)
