Discussion: Adblue off
Vieux 19/11/2022, 20h47
mexicain
Avatar de mexicain
mexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to behold
[QUOTE=angels59;956992]Salut mexicain
Essais ce fichier ,j'expérimente le soft pour vérifier sa qualité , donc les retours sont très important , tiens nous au courant ;)
Ton outil devra corriger le checksum bien sur .
ECU SELECTED: PEUGEOT BOSCH MD1CS003
FILE LOADED OK: CITROËN C3III (B618) 1.5 BlueHDi 16V S&S 102 cv CARTO MD1CS003.bin
FILE SIZE: 8,0MB
-------------- ECU INFO --------------
ECU: MD1CS003
BOSCH SW.: 10SW06074210SW073518
------------ END ECU INFO ------------
DTC P12B3 Disabled! found 1 time(s) -
DTC P1F00 Disabled! found 476 time(s) -
DTC P2032 Disabled! found 1 time(s) - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2
DTC P2047 Disabled! found 1 time(s) - Reductant Injector Circuit/Open Bank 1 Unit 1
DTC P204A Disabled! found 1 time(s) -
DTC P208E Disabled! found 1 time(s) -
DTC P20E8 Disabled! found 3 time(s) - Reductant Low Pressure
DTC P20E9 Disabled! found 2 time(s) -
DTC P20EE Disabled! found 1 time(s) -
DTC P2048 Disabled! found 1 time(s) - Reductant Injector Circuit Low Bank 1 Unit 1
DTC 01349 Disabled! found 1 time(s) -
DTC 01350 Disabled! found 1 time(s) -
DTC 0171B Disabled! found 2 time(s) -
DTC 02202 Disabled! found 1 time(s) -
DTC 02BA9 Disabled! found 1 time(s) -
DTC 0C10E Disabled! found 1 time(s) -
DTC 0C29D Disabled! found 1 time(s) -
DTC 0C29E Disabled! found 1 time(s) -
DTC 0C40F Disabled! found 5 time(s) -
DTC P1349 Disabled! found 1 time(s) -
DTC P1350 Disabled! found 1 time(s) -
DTC P171B Disabled! found 2 time(s) -
DTC P2202 Disabled! found 1 time(s) - NOx Sensor Circuit Low Input Bank 1
DTC P2BA9 Disabled! found 1 time(s) -
DTC U010E Disabled! found 1 time(s) -
DTC U029D Disabled! found 1 time(s) -
DTC U029E Disabled! found 1 time(s) -
DTC U040F Disabled! found 5 time(s) -
DTC P2049 Disabled! found 1 time(s) - Reductant Injector Circuit High Bank 1 Unit 1
DTC P220B Disabled! found 1 time(s) -
DTC 00562 Disabled! found 1 time(s) -
DTC P0562 Disabled! found 1 time(s) - System Voltage Low
DTC P208B Disabled! found 1 time(s) -
DTC P2084 Disabled! found 4 time(s) - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 2
DTC P220A Disabled! found 1 time(s) -
DTC U059E Disabled! found 5 time(s) -
DTC P2204 Disabled! found 1 time(s) - NOx Sensor Circuit Intermittent Input Bank 1
Cordialement
j ai aussi tester ton fichier la voiture démarre tout le voyant qui clignote impossible a réinitialiser voici une photo des defaut
mexicain est déconnecté   Réponse avec citation
