Vieux 01/12/2022, 14h12
papy53
Avatar de papy53
papy53 is an unknown quantity at this point
Par défaut Code P205C sur Seat Alhambra 2 (2011)
Bonjour à tous,j'ai trouvé ceci sur un forum US ,est ce que quelqu'un a déjà fait ce job ?
Je joins le texte et photos Anglais/Français.
Cheap DIY Fix for P205c & P205b Temp Sensor
Hello,
This is my first post as a new member to TDI club.
I recently had the Check Engine Light come on with the P205c/P205b fault codes. I did some extensive research because I did not want to spend $475 on a new part to fix this as my Passat just went out of warranty.
The failed temperature sensor is integrated inside the AD Blue Tank and you cannot change this sensor out at the component level. The part number that contains this sensor is 561-198-970.
This temp sensor monitors the temperature of the DEF fluid and if it drops below -11 Degrees Fahrenheit then it activates the heater inside this tank. Since I live in Texas I don't really have to worry about -11 degree temperatures here. There are two ways to fix this issue yourself if you do or do not live in a climate where the weather gets below -11.
before you start, purchase a 10k Ohm Resistor or Automotive grade 10k Ohm Submersible Thermistor, Solder, heatshrink.
Mouser Electronics or eBay are two places to find these components.
Once you have all your parts ready, Here are the steps to take:
Use the jack in your trunk to lift up the rear passenger side until the tire just barely comes off the ground.
Remove all the torx screws that are around the rear fender well.
There should be 5 of them if I'm not mistaken.
Pull out the plastic part of your lower bumper/quarter panel.
Just enough to give you a few extra inches for removing the tank.
The tank is held in place by 3 bolts, remove them and drop the tank down. (Be ready to catch it if it's full of DEF as it will be heavy)
Find the Wire harness that is secured to the filler neck of the tank.
Pins 3 & 4 are the temp sensor wires connected to the failed temp sensor inside the tank. They are purple/yellow and Brown and on the other side of the connector going into the tank the colors are Black & White.
Easy Fix option if you're lazy or live in a warm weather climate:
From the other side of the plug, cut the wires that are going into the tank (Black & White wires) . Make sure to leave enough slack for the resistor or thermistor.
Solder & heatshrink a 10K ohm resistor or 10k OHM Thermistor to the cut wires. Make sure that the connections are made back to the computer and not to the tank. Leave the wires from the tank cut off and just use some tape or heat shrink to protect them as they will never be used again.
For Cold Climate Areas:
Take a picture of the tank before you start, ensure you know the position of all the cables, hoses and top pump position.
Remove all the harness, Hoses and Pump from the Top of the tank.
Unscrew the Top of the tank and remove the rubber grommet and plastic circular housing from the tank. The circular housing is locked in, just twist it counter clock wise and it will become detached from the tank.
Find/trace the wires inside the tank that are associated with pins 3 & 4 on the outside of the tank. (black & white wires.)
Using a Submersible Automotive Grade 10k Ohm thermistor,
Solder/Heatshrink the thermistor to these wires and make sure the probe part of the thermistor is located in the small part of the tank with the other sensors. Some Drilling may be necessary.
As I live in Texas, I did not pursue or try the Cold Climate option I described above.
Also, as I was troubleshooting this issue, I ******ly drilled a small hole in the plastic and extended the wires so I could access them from my trunk when I was trying to figure out the correct resistor to use.
At the time I was not sure what resistor size to use. After trying different values. I borrowed a friends 2014 TDI and used my meter to find the value VW uses for this component.
The 10k Ohm Resistance reading is equal to 25 degrees Celsius or 77 degrees Fahrenheit. This resistance reading will make the computer think the DEF fluid is at this temperature.
In the pictures attached I show the connections to look for.
(See Links below)
If you don't want to drop the tank, another option is to cut the wires from the connector by the rear wheel and add the resistor or thermistor from there. It also uses pins 3 & 4 on one of the wire harnesses.
Once I added the 10K Ohm resistor, it took me about 4 days of everyday driving before my Check Engine Light went out. I'm not sure of the exact number but the computer needs to go through a certain number of "driving cycles" before it realizes the problem is fixed and the light goes off.
One more thing to note if your adblue tank is full, unplug the harness/hose and dump all the DEF fluid into a large clean container.
This will help out as its very hard to get the tank bolted back into position. Once the nearly empty tank is bolted back in place, just re-fill it as you normally would. I use the small Filler bottle from VW. I have a hole cut out in the bottom of it and use a funnel to re-fill that small bottle. Once its full I push the bottle down to let the DEF enter the tank. Repeat until your full....
I hope this post helps.
No sense in spending close to $500 when you can replace this with a resistor or thermistor that costs less than a dollar. (And an hour or two of your time)
~Russ
Pictures to help you:
http://i81.photobucket.com/albums/j2...h/IMG_2307.jpg
http://i81.photobucket.com/albums/j2...h/IMG_2305.jpg
http://i81.photobucket.com/albums/j2...h/IMG_2303.jpg
Solution de bricolage bon marché pour capteur de température P205c et P205b
Ceci est mon premier message en tant que nouveau membre du club TDI.
J'ai récemment fait s'allumer le témoin Check Engine avec les codes d'erreur P205c/P205b. J'ai fait des recherches approfondies parce que je ne voulais pas dépenser 475 $ sur une nouvelle pièce pour résoudre ce problème, car ma Passat venait de sortir de la garantie.
Le capteur de température défectueux est intégré à l'intérieur du réservoir AD Blue et vous ne pouvez pas changer ce capteur au niveau du composant. Le numéro de pièce qui contient ce capteur est 561-198-970.
Ce capteur de température surveille la température du liquide DEF et s'il descend en dessous de -11 degrés Fahrenheit, il active le chauffage à l'intérieur de ce réservoir. Depuis que je vis au Texas, je n'ai pas vraiment à m'inquiéter des températures de -11 degrés ici. Il existe deux façons de résoudre ce problème vous-même si vous vivez ou non dans un climat où le temps descend en dessous de -11. avant de commencer, achetez une résistance 10k Ohm ou une thermistance submersible 10k Ohm de qualité automobile, une soudure, un thermorétractable.
Mouser Electronics ou eBay sont deux endroits pour trouver ces composants.
Une fois que vous avez toutes vos pièces prêtes, voici les étapes à suivre :
Utilisez le cric dans votre coffre pour soulever le côté passager arrière jusqu'à ce que le pneu se détache à peine du sol.
Retirez toutes les vis torx qui se trouvent autour du puits de garde-boue arrière.
Il devrait y en avoir 5 si je ne me trompe pas.
Retirez la partie en plastique de votre pare-chocs inférieur/panneau de custode.
Juste assez pour vous donner quelques centimètres supplémentaires pour retirer le réservoir.
Le réservoir est maintenu en place par 3 boulons, retirez-les et déposez le réservoir. (Soyez prêt à l'attraper s'il est plein de DEF car il sera lourd)
Trouvez le faisceau de câbles qui est fixé au goulot de remplissage du réservoir.
Les broches 3 et 4 sont le capteur de températurefils de capteur connectés au capteur de température défectueux à l'intérieur du réservoir. Ils sont violet/jaune et marron et de l'autre côté du connecteur allant dans le réservoir les couleurs sont noir et blanc.
Option Easy Fix si vous êtes paresseux ou si vous vivez dans un climat chaud :
De l'autre côté de la prise, coupez les fils qui vont dans le réservoir (fils Noir & Blanc) . Assurez-vous de laisser suffisamment de jeu pour la résistance ou la thermistance.
Souder et thermorétracter une résistance de 10K ohms ou une thermistance de 10k OHM aux fils coupés. Assurez-vous que les connexions sont faites vers l'ordinateur et non vers le réservoir. Laissez les fils du réservoir coupés et utilisez simplement du ruban adhésif ou du thermorétractable pour les protéger car ils ne seront plus jamais utilisés.
Pour les régions à climat froid :
Prenez une photo du réservoir avant de commencer, assurez-vous de connaître la position de tous les câbles, tuyaux et position de la pompe supérieure.
Retirez tout le faisceau, les tuyaux et la pompe du haut du réservoir.
Dévissez le haut du réservoir et retirez l'œillet en caoutchouc et le boîtier circulaire en plastique du réservoir. Le boîtier circulaire est verrouillé, il suffit de le tourner dans le sens inverse des aiguilles d'une montre et il se détachera du réservoir.
Trouvez/tracez les fils à l'intérieur du réservoir qui sont associés aux broches 3 et 4 à l'extérieur du réservoir. (fils noirs et blancs.)
À l'aide d'une thermistance submersible de qualité automobile 10k Ohm,
Soudez/rétractez la thermistance à ces fils et assurez-vous que la partie sonde de la thermistance est située dans la petite partie du réservoir avec les autres capteurs. Certains perçages peuvent être nécessaires.
Comme je vis au Texas, je n'ai pas poursuivi ni essayé l'option de climat froid que j'ai décrite ci-dessus.
De plus, alors que je résolvais ce problème, j'ai en fait percé un petit trou dans le plastique et prolongé les fils afin de pouvoir y accéder depuis mon coffre lorsque j'essayais de déterminer la bonne résistance à utiliser.
À l'époque, je ne savais pas quelle taille de résistance utiliser. Après avoir essayé différentes valeurs. J'ai emprunté le TDI 2014 d'un ami et j'ai utilisé mon compteur pour trouver la valeur que VW utilise pour ce composant.
La lecture de résistance de 10k Ohm est égale à 25 degrés Celsius ou 77 degrés Fahrenheit. Cette lecture de résistance fera penser à l'ordinateur que le liquide DEF est à cette température.
Dans les photos ci-jointes, je montre les connexions à rechercher.
(Voir les liens ci-dessous)
Merci à tous
papy53 est déconnecté   Réponse avec citation
