Vieux 22/12/2022, 20h29
LakiF
Avatar de LakiF
LakiF is on a distinguished road
Check the fuse and relay box in the engine compartment, see if there is corrosion on the connectors and wiring, the clio 2 has a known problem with water leaks. It often happens that the cover of the fuse and relay in the engine compartment is not properly installed, and then water enters and after a while inexplicable problems begin to arise.
Greeting.
LakiF est déconnecté   Réponse avec citation
