Vieux 22/12/2022, 21h38
zygraal
Avatar de zygraal
zygraal is an unknown quantity at this point
Envoyé par LakiF Voir le message
Check the fuse and relay box in the engine compartment, see if there is corrosion on the connectors and wiring, the clio 2 has a known problem with water leaks. It often happens that the cover of the fuse and relay in the engine compartment is not properly installed, and then water enters and after a while inexplicable problems begin to arise.
Greeting.
Tout a été fait de ce coté et rien n'est coupé.
J'arrête les frais, merci.
zygraal est déconnecté   Réponse avec citation
