Discussion: airbag 207 alim
Vieux 03/06/2023, 23h36
martinn
Avatar de martinn
martinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to beholdmartinn is a splendid one to behold
merci cedric gràce a ton schema j ai resolu le probleme, il vient soit du fil violet pin4 qui est le +apc soit de la bsi , je croit que le fil violet à été arraché derriere le ventilo
martinn est déconnecté   Réponse avec citation
The Following User Says Thank You to martinn For This Useful Post:
Cedric79 (04/06/2023)
