Vieux 03/09/2023, 12h41
SaTouF
Avatar de SaTouF
SaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond repute
oups peut etre tu n'as pas l'abo??
au besoin,je peut te le faire, tu m'envois ton ecu et ta lecture bench
effectivement, j'ai pas le full.
mais c'est bon,
j'ai remis l'ori en boot avec un autre tool.
la je viens de retenter l'écriture (3eme fois) et,
c'est passé crème !
Code:
  ---------- Connect Started ------------------------------
Connexion en cours...
Connexion OK
Processeur TC1797 détecté.
REG SCU_CHIPID: 00009101
REG PFlash0 FSR: 00A50000
REG PFlash0 FCON: 00010505
REG PFlash0 PROCON0: 0000DFFF
REG PFlash0 PROCON1: 00000000
REG PFlash0 PROCON2: 00008030
REG PFlash1 FSR: 00250000
REG PFlash1 FCON: 00010505
REG PFlash1 PROCON0: 0000DFFF
REG PFlash1 PROCON1: 00000000
REG PFlash1 PROCON2: 00000000
ID unique de la puce: 4100080405E09485740800101118FF00
FLASH Interne
Configuration mémoire
Secteur	 Adresse	 Taille		 Type
01	 0xA0000000	 0x00004000	 RW 02	 0xA0004000	 0x00004000	 RW 03	 0xA0008000	 0x00004000	 RW 04	 0xA000C000	 0x00004000	 RW 05	 0xA0010000	 0x00004000	 OTP 06	 0xA0014000	 0x00004000	 OTP 07	 0xA0018000	 0x00004000	 RW 08	 0xA001C000	 0x00004000	 RW 09	 0xA0020000	 0x00020000	 RW 10	 0xA0040000	 0x00040000	 RW 11	 0xA0080000	 0x00040000	 RW 12	 0xA00C0000	 0x00040000	 RW 13	 0xA0100000	 0x00040000	 RW 14	 0xA0140000	 0x00040000	 RW 15	 0xA0180000	 0x00040000	 RW 16	 0xA01C0000	 0x00040000	 RW 17	 0xA0200000	 0x00004000	 RW 18	 0xA0204000	 0x00004000	 RW 19	 0xA0208000	 0x00004000	 RW 20	 0xA020C000	 0x00004000	 RW 21	 0xA0210000	 0x00004000	 RW 22	 0xA0214000	 0x00004000	 RW 23	 0xA0218000	 0x00004000	 RW 24	 0xA021C000	 0x00004000	 RW 25	 0xA0220000	 0x00020000	 RW 26	 0xA0240000	 0x00040000	 RW 27	 0xA0280000	 0x00040000	 RW 28	 0xA02C0000	 0x00040000	 RW 29	 0xA0300000	 0x00040000	 RW 30	 0xA0340000	 0x00040000	 RW 31	 0xA0380000	 0x00040000	 RW 32	 0xA03C0000	 0x00040000	 RW
EEPROM Interne
01	 0xAFE00000	 0x00008000	 RW 02	 0xAFE10000	 0x00008000	 RW
Contrôle du mot de passe...
FLASH déprotégée
Mot de passe OK
  ---------- Connect Finished ( Time: 00:00:12 ) ----------
  ---------- Write Int Flash Started ------------------------------
File loaded: DaVinci_Deluxe(VAG BOSCH EDC17CP44_ADBLUE_).bin ( 4 MB )
Calcul du checksum en cours, veuillez patienter...
Checksum corrigé
Ecriture...
CRC32 de la lecture: A99E6D06
Ecriture...
Passage secteur 1 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 2 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 3 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 4 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 5 / 32 - Secteur OTP - l'écriture n'est pas possible
Passage secteur 6 / 32 - Secteur OTP - l'écriture n'est pas possible
Passage secteur 7 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 8 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 9 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 10 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 11 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 12 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 13 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 14 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 15 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 16 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 17 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 18 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 19 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 20 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 21 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 22 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 23 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 24 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 25 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 26 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Effacement secteur 27 / 32, adresse: 0xA0280000, tille: 256 KB
Ecriture secteur 27 / 32, adresse: 0xA0280000, taille: 256 KB
Vérification secteur 27 / 32, adresse: 0xA0280000, taille: 256 KB
Passage secteur 28 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Effacement secteur 29 / 32, adresse: 0xA0300000, tille: 256 KB
Ecriture secteur 29 / 32, adresse: 0xA0300000, taille: 256 KB
Vérification secteur 29 / 32, adresse: 0xA0300000, taille: 256 KB
Effacement secteur 30 / 32, adresse: 0xA0340000, tille: 256 KB
Ecriture secteur 30 / 32, adresse: 0xA0340000, taille: 256 KB
Vérification secteur 30 / 32, adresse: 0xA0340000, taille: 256 KB
Passage secteur 31 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Passage secteur 32 / 32, le CRC du secteur dans le fichier et dans la flash est identique
Taille écrite: 768 KB
Ecriture réussie.
  ---------- Write Int Flash Finished ( Time: 00:04:31 ) ----------
SaTouF est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to SaTouF For This Useful Post:
dede83 (03/09/2023), yann3 (03/09/2023), zingilingiling (04/09/2023)
