Vieux 09/09/2023, 18h34
Badis10
Avatar de Badis10
Badis10 is an unknown quantity at this point
Hello tout le monde,
J'ai fais venir un électricien qui m'a confirmé que le cablage est ok. D'un autre coté, j'ai acheté un boitier papillon neuf, le problème reste le meme !!
Voici donc la liste de l'intégralité des erreurs du véhicule :
11 Faults Found:
17952 - Angle Sensor 1 for Throttle Actuator (G187)
P1544 - 35-10 - Signal too Large - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - Intermittent
18088 - Reset-Resistant Limp-Mode Active
P1680 - 35-10 - - Intermittent
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 35-00 - Short to Ground
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-00 - Implausible Signal
17967 - Throttle Body (J338)
P1559 - 35-00 - Fault in basic settings
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 35-00 - Short to Ground
18252 - Please check DTC Memory of Electric Load Controller
P1844 - 35-10 - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 35-10 - No Activity - Intermittent
Readiness: 1010 0101
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.clb
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H03 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002085
Shop #: WSC 00788 785 00200
VCID: 010930035B09039BCC-515A
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 62
Mileage: 139353 km
Time Indication: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 139353 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-907-044.lbl
Part No: 6Q0 907 044 C
Component: CLIMAtronic PQ24 0301
Shop #: WSC 00000 000 00000
VCID: 326BAFCFAE2F680305-515A
1 Fault Found:
00792 - A/C Pressure Switch (F129)
000 - -
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00AF BN-SG. 1S34
Coding: 26270
Shop #: WSC 00788
VCID: 3C7781F72C6BAE73DF-515A
3 Faults Found:
49-10 - No Communications - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
01336 - Company Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 19 AIRBAG VW51 0P 0008
Coding: 12601
Shop #: WSC 00788
VCID: 2C57B1B7DC0B3EF34F-515A
No fault code found.
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 823 F
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01131
Shop #: WSC 00000
VCID: 356194D30F417F3B20-515A
WVWZZZ9NZ6Y015395 VWZ7Z0E1596612
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70EF65C730A31A1333-515A
2 Faults Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 00000
VCID: 6FED66BB2D9D05EB2A-5178
1 Fault Found:
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 E
Component: 3F Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 3D718CF33771A77BE8-4B18
1 Fault Found:
End-------------------------(Elapsed Time: 03:16)--------------------------
Thursday,15,June,2023,18:04:25:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVWZZZ9NZ6Y015395 License Plate:
Mileage: 139350km-86588mi Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y015395 Mileage: 139350km-86588miles
Address 01: Engine Labels: 03E-906-033-AZQ.lbl
Part No: 03E 906 033 R
Component: 1,2l/4V SIMOS3 G00HS7002
Coding: 00071
Shop #: WSC 00788
VCID: 2F6DA6BBED1D45EB6A-515A
Readiness: 1110 0101
Coding: 0002085
VCID: 010930035B09039BCC-5178
Coding: 26270
Shop #: WSC 00788
VCID: 3C7781F72C6BAE73DF-5178
1 Fault Found:
Coding: 12601
Shop #: WSC 00788
VCID: 2C57B1B7DC0B3EF34F-5178
Coding: 01131
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 00788
1 Fault Found:
Coding: 10110
Shop #: WSC 00000
VCID: 6FED66BB2D9D05EB2A-515A
Coding: 00019
Shop #: WSC 00788
VCID: 3D718CF33771A77BE8-4B00
1 Fault Found:
End-------------------------(Elapsed Time: 03:23)--------------------------
Friday,18,August,2023,12:03:43:00009
www.Ross-Tech.com
Coding: 00071
Shop #: WSC 00788
8 Faults Found:
Coding: 0002085
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 63
Mileage: 139353 km
Time Indication: 0
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 139353 km
Time Indication: 0
1 Fault Found:
000 - -
Coding: 26270
Shop #: WSC 00788
5 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
28-10 - Short to Plus - Intermittent
00906 - Horn (H1)
00975 - Heated Rear Window (Z1)
Coding: 12601
Shop #: WSC 00788
Coding: 01131
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 00788
1 Fault Found:
Coding: 10110
Shop #: WSC 00000
Coding: 00019
Shop #: WSC 00788
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-00 - Supply Voltage Too Low
Savez-vous si je peux "confier" la voiture à un garage pour faire les réparations ? Je suis sur Marseille, et le sujet devient de moins en moins évident.
Bien à vous,
Badis10 est déconnecté   Réponse avec citation
