Discussion: UCH megane 3
Vieux 15/02/2013, 11h04
didi_du_93000
Avatar de didi_du_93000
Pouvoir de réputation: 25
didi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to behold
If you swap the MCU inside BCU no need more.
But if your ECU also had swum, you need to swap immo information inside original ECU and second the second hand.
sometime after all this step you need to learn the card with a tool (i'm talking about old card).
didi_du_93000 est déconnecté   Réponse avec citation
