Envoyé par ricards99
comment utiliser le patch tlcdfix.exe? et a quoi elle sert?
@ scarymistake: please what is tlcdfix.exe for? and how to use it?
thanks
Je pense qu'il doit faire la même chose que celui développer par Namek :
Envoyé par Namek
I wrote a simple application, which should help you  . It's a DiagBox TLCD Fix.
.NET 2.0 is required.
This application removes all lines containing:
<Door Name="TLCD_ASSISTANCE_CODE" Number="4"/>
from all *.XML files in a folder (by default path is C:\AWRoot\dtrd\comm\XMLTLCD\, but you can specify the path to different location). This also creates a copy of the file, with the extension *.BAK.
Cheers
