Discussion: VW passat
Vieux 31/10/2023, 14h50
dom570
Avatar de dom570
Pouvoir de réputation: 7
dom570 has a spectacular aura aboutdom570 has a spectacular aura about
bonjour,
Ross-Tech, LLC
881 Sumneytown Pike
Lansdale PA 19446, USA
Tel: +1 267 638 2300
Shop Info F.A.Q. Download/Update Manual Upgrades Literature Wiki Search
01222
Jump to:navigation, search
Contents
1 01222 - Crash Sensor Side Airbag; Passenger Side (G180)
1.1 01222 - Crash Sensor Side Airbag; Passenger Side (G180): Faulty
1.2 01222 - Crash Sensor Side Airbag; Passenger Side (G180): Open or Short to Plus
1.2.1 Possible Symptoms
1.2.2 Possible Causes
1.2.3 Possible Solutions
1.3 01222 - Crash Sensor Side Airbag; Passenger Side (G180): No or Incorrect Basic Setting / Adaptation
1.3.1 Possible Symptoms
1.3.2 Possible Causes
1.3.3 Possible Solutions
1.3.4 Special Notes
1.4 01222 - Crash Sensor Side Airbag; Passenger Side (G180): Implausible Signal
1.4.1 Possible Symptoms
1.4.2 Possible Causes
1.4.3 Possible Solutions
1.4.4 Special Notes
Possible Symptoms
Airbag Warning Light ON
Possible Causes
Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180) faulty
Airbag Control Module (J234) faulty
Possible Solutions
Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180)
Replace Crash Sensor Side Airbag; Passenger Side (G180)
Replace Airbag Control Module (J234)
Possible Symptoms
Possible Causes
Wrong Crash Sensor Side Airbag; Passenger Side (G180) installed
Newly Installed Airbag Module is Not Compatible With Crash Sensor(s)
Possible Solutions
Install correct Crash Sensor Side Airbag; Passenger Side (G180)
Install Airbag Module that is Compatible With Crash Sensor(s)
Special Notes
The US Market (9M) Jetta has a common Airbag Control Module replacement conflict with the existing Crash Sensors. This is mentioned in TSB # 69-08-04 (TPI-2011170) with the following example:
When control module 1C0-909-605-F-004 (coded to 12340) is replaced with 1C0-909-605-F-01E the original Crash Sensors are not compatible. The new module will refuse coding if DTCs 01221, 01222, 01738, or 1739 are stored. This is also noted here: Airbag Coding
The Crash Sensors can be checked by using the control module identification and the measuring blocks.
Address 15: Airbags
Controller: 1T0 909 605
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determined by checking Measuring Value Block (MVB) 009.
Possible Symptoms
Possible Causes
Wrong/Incompatible Crash Sensor Side Airbag; Passenger Side (G180) installed
Possible Solutions
Check Crash Sensor Side Airbag; Passenger Side (G180) Part Number
Special Notes
When found on 2019 - 2022 Atlas, Atlas Cross Sport, Golf, Golf Wagon, Jetta, Tiguan and Taos, please see TT 97-21-02 for possible wiring harness issue:
https://static.nhtsa.gov/odi/tsbs/20...08280-0001.pdf NHTSA
May also find DTCs U0199, U0200, B1017 or B1036.
Category:
Fault Codes
Navigation menu
Categories
Main Page
Diagnostic Procedures
Common Procedures
Fault Codes
Retrofitting
Immobilizer
Tools
Log in
Unless otherwise noted, all content on this site is Copyright © 2000-2017 by Ross-Tech LLC. All rights reserved.
"VCDS", "VCDS-Mobile", "HEX-NET" and "HEX-V2" are Registered Trademarks of Ross-Tech, LLC.
Ross-Tech is not affiliated with the Volkswagen Group in any way.
dom570 est déconnecté   Réponse avec citation
