Vieux 21/06/2009, 15h12   #1
t77
Avatar de t77
t77 is an unknown quantity at this point
Par défaut 307 BSI need virgin dump
Hi,my friend i'm new in this forum,i'm glad to talk with you,i want replace bad bsi in peugeot 307 1,6HDI 2005 I have found used bsi and writed ST95128,with virgin file,but when i start pps insert vin,pin code,and it tell me:bsi can't start program,please help,me.thanks.
t77 est déconnecté   Réponse avec citation
Vieux 21/06/2009, 15h47   #2
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1331
Amine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond reputeAmine-TE has a reputation beyond repute
maybe you are using bad virgin file.
Je ne donne pas d'aide en privé.
Amine-TE est déconnecté   Réponse avec citation
Vieux 21/06/2009, 16h51   #3
t77
Avatar de t77
ok this is my virgin dump
Type de fichier : rar bsi_00.rar (1,1 Ko, 70 affichages)
The Following User Says Thank You to t77 For This Useful Post:
GUILLE (02/11/2013)
Vieux 21/06/2009, 18h00   #4
Amine-TE
Fondateur
Avatar de Amine-TE
i don't think that's virgin !
Vieux 21/06/2009, 18h16   #5
t77
Avatar de t77
Hi again ,i have question for you,maybe you have a virgin dump for my BSI ,i have many software and dumps for exchange ,maybe you need somthing.Regards t77
Vieux 21/06/2009, 18h18   #6
Amine-TE
Fondateur
Avatar de Amine-TE
no, beleive me i don't have for that model,
i check with others virgin dump and it appear like not ok !!!
is just for that i told you that's not ok !
Vieux 21/06/2009, 18h23   #7
t77
Avatar de t77
Ok thanks for quickly reply.Now i know thats i must search for good dumps .
Thank You.
Vieux 24/06/2009, 02h17   #8
Mrpromega
Avatar de Mrpromega
Mrpromega is a jewel in the roughMrpromega is a jewel in the roughMrpromega is a jewel in the roughMrpromega is a jewel in the rough
Hi !
Sorry but your dump remains not virgin
The details refering to your dump :
VIN : VF33HRHR 9310(x)187
& the PIN refering is : QC(x)T
So, here you are what are you seeking for !
Pass on PM, Best regards!
Type de fichier : rar virgin.rar (1,1 Ko, 70 affichages)
Mrpromega est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to Mrpromega For This Useful Post:
ggabo71 (24/02/2010), GUILLE (02/11/2013), medhj (20/12/2011), t77 (26/06/2009)
Vieux 26/06/2009, 17h11   #9
t77
Avatar de t77
Thanks of lot Mrpromega for this dump i will be try use it.
Vieux 26/06/2009, 17h24   #10
Mrpromega
Avatar de Mrpromega
Welcome
give us the result, Best regards !
Vieux 11/08/2009, 00h38   #11
t77
Avatar de t77
Ok today I was programmed your dump of BSI and car started. This dump really work after configuration....Many thanx Mrpromega for help. U are GREAT.
Best Regards
Vieux 11/08/2009, 01h19   #12
Mrpromega
Avatar de Mrpromega
Welcome again
Best regards ...
Vieux 13/08/2009, 17h27   #13
msv81
Avatar de msv81
msv81 is an unknown quantity at this point
Hello, I have troubles with engine starting on Peugeot 307 2.0 HDI 66kW 90hp (DW10TD) 2002 year.
It seems that immo blocks engine. Can comebody help me with fixing ecu and bsi dumps?
ECU: siemens 93c56
BSI: 912dg128
See original files in attachment.
Type de fichier : rar ecu-bsi.rar (570 octets, 28 affichages)
Dernière modification par msv81 ; 13/08/2009 à 17h32.
msv81 est déconnecté   Réponse avec citation
Vieux 14/08/2009, 08h04   #14
t77
Avatar de t77
Hello write more about what happens with BSI and ECU? Bsi is VALEO? ECU siemens number please.
Regards
Vieux 14/08/2009, 12h52   #15
msv81
Avatar de msv81
Envoyé par t77 Voir le message
Regards
Battery was completely discharged (the reason was in generator set belt). I've took power from another auto to start engine. Everything was fine. Then I had a short trip (about 1 km), stopped engine, disconnected and charged battery. Then I connected battery again, but after that immo indicator on panel blinks very often and I can't lock the car, lift windows up and down and start engine. But audio and all lamps work.
I guess ecu is Siemens_SID_801_5WS40030B-T.
I'll clarify ecu and bsi numbers today.
Dernière modification par msv81 ; 14/08/2009 à 12h58.
Ecu delphi virgin file Amine-TE Immobilizer dumps/solutions 17 25/03/2015 12h19
Please virgin BSI file for 206 peppery Immobilizer dumps/solutions 1 30/05/2009 20h10
Fuseau horaire GMT +1. Il est actuellement 09h49.
