Vieux 03/12/2015, 10h11   #1
ryosaeba
Avatar de ryosaeba
Pouvoir de réputation: 26
ryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud ofryosaeba has much to be proud of
Par défaut 406 qui ne s'arrête pas
slt les amis je suis embeté avec une 406 2.0 hdi 110cv rhz qui demarre mais jne coupe pas il faut la faire caler pour qu'elle s'arrête (sinon je retire la clé du neiman mais reste demarrée) et quand j'enleve la clé du neiman j'ai des voyant qui reste toujours allumés : moteur frein huile ... le garage a déjà changer le bsi , bsm, ecu, neiman, electrovanne pompe hp mais toujours rien avez vous une idée sur la provenance du problème ?
merci à tous
AVDI Full officiel, Ktag, Kess,...
Orange 5, GQ-4X, Upa,...
all diag...
swiftec, winols...
ryosaeba est déconnecté   Réponse avec citation
Vieux 03/12/2015, 10h52   #2
YUMBO
Avatar de YUMBO
Pouvoir de réputation: 23
YUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud of
C'est surement ton relais double ....
YUMBO est déconnecté   Réponse avec citation
Vieux 03/12/2015, 11h45   #3
tarik_electronic
Avatar de tarik_electronic
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
Régulateur de pression de carburant..
Lo conecteur avec 2 cable
1 vien de relais du ststeme k43
2 vien de calcul ( fil 50)
tarik_electronic est déconnecté   Réponse avec citation
Vieux 03/12/2015, 11h54   #4
Binbin
Avatar de Binbin
Contrôle si relais d'alimentation boitier d'injection ne restent pas collés.
Binbin est connecté maintenant   Réponse avec citation
Vieux 03/12/2015, 18h48   #5
manudiag
Avatar de manudiag
manudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nice
du cote de ta bsi tu as deux relai noir rectangulaire, controle les, ils sont surement oxyde et hs , j ai déjà eu le cas,entrée d eau par le pare brise dans mon cas
manudiag est déconnecté   Réponse avec citation
Vieux 04/12/2015, 21h17   #6
jphp
Avatar de jphp
Pouvoir de réputation: 250
Envoyé par ryosaeba Voir le message
merci à tous
salut , non ca ne devrait pas etre ! c impossible ! sur HDI, sauf si le régulateur est bloqué
donne le code moteur sltp
@ bon weekend
Vieux 04/12/2015, 21h34   #7
ECU diag
Avatar de ECU diag
Pouvoir de réputation: 63
salut tout le monde
j'ai deja eu ce probleme sur un expert hdi quand je retirer les clé il resté demarré et le contact resté allumé.
il fallait débranché et rebranché la batterie pour couper le contact
pas de défaut au diag
aprés mainte recherche j'ai débranché le bloc abs et sa remarché normal alors j'ai fini par changé le bloc abs
ECU diag est connecté maintenant   Réponse avec citation
Vieux 04/12/2015, 21h40   #8
amar
Avatar de amar
amar is a glorious beacon of lightamar is a glorious beacon of lightamar is a glorious beacon of lightamar is a glorious beacon of lightamar is a glorious beacon of light
salut l ami fait un essai en debranchant l alternateur
amar est déconnecté   Réponse avec citation
Vieux 04/12/2015, 21h54   #9
ryosaeba
Avatar de ryosaeba
slt a tous et merci pour vos reponse, j'ai debranché l'alternateur tj pareil, sinon jphp oui c'est un hdi 110cv 2.0l edc15c2 3 plug moteur rhz, le bsi et le bsm ont été changer mais tj le meme soucis
all diag...
swiftec, winols...
Vieux 04/12/2015, 22h16   #10
amar
Avatar de amar
moteur a l aret quant tu coupe le contact tes voyant reste allumé
Vieux 04/12/2015, 22h25   #11
felmo
Avatar de felmo
felmo is a jewel in the roughfelmo is a jewel in the roughfelmo is a jewel in the roughfelmo is a jewel in the rough
Salut, est ce que ralentit seulement, ou bien elle repond à l'acceleration
normalement ,quand tu aura enlevé la clé evidemment?
felmo est déconnecté   Réponse avec citation
Vieux 05/12/2015, 07h23   #12
stephmargot
Avatar de stephmargot
stephmargot will become famous soon enoughstephmargot will become famous soon enough
bonjour a tous
je pense que ton +APC reste allumé meme en arrétant le moteur alors :
-Probleme dans le niman ou bien ton bsi
verifi au pps ton +APC et tu trouvera
cdlt
stephmargot est déconnecté   Réponse avec citation
Vieux 05/12/2015, 12h35   #13
jphp
Avatar de jphp
salut, n'aurai tu pas changé le relai double, ? par un qui n'est pas compatible ? couleur noir, marron ?
RHS plutot le code moteur non ?
Dernière modification par jphp ; 05/12/2015 à 13h01.
Vieux 05/12/2015, 13h28   #14
manudiag
Avatar de manudiag
as tu regarde les relai donc je te parler plus haut il te maintienne le contact presque comme si tu n avais pas retirer la clef , deux cas pour ce probleme dans ma concession
Vieux 05/12/2015, 14h16   #15
rahmani2008
Avatar de rahmani2008
rahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the rough
il est tres probable que vous avez un plus permanent soit au niveau du neiman meme en position off soit un shunt entre deux fils un plus apres contact et l'autre normalement plus batterie ce qui laisse toujours un plus permanent
je vous conseille de vérifier l’alimentation du calculateur 0V contact off 12V contact mis ( utilise autodata pour reperer le fil du plus apres contact au niveau du connecteur du calculateur)
rahmani2008 est déconnecté   Réponse avec citation
ventilateur ne s’arrête pas rahmani2008 Peugeot, Citroën 12 06/10/2015 13h52
Moteur ne s'arrete pas bmw78 Mécanique générale 2 15/06/2015 15h12
P 308 1,4 ventilateur ne s’arrête pas digicar Peugeot, Citroën 5 22/11/2013 12h10
Pb ventilateur ne s'arrete pas 307 HDI belaidi_enp Peugeot, Citroën 1 11/11/2013 09h21
207 HDI s’arrête seul alilou Peugeot, Citroën 8 17/05/2011 09h33
Fuseau horaire GMT +1. Il est actuellement 20h19.
