Vieux 02/10/2018, 16h05   #1
khoums
Avatar de khoums
khoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to all
Par défaut Calculateur dae C2
salut les amis j'ai un ami en panne de calculateur de direction sur une c2
la question est : y'a t'il un codage a effectuer dessus ? A t'il le code immo ? si oui faut lire quoi ?
merci pour vos reponses les amis
LES COÏNCIDENCES SONT UNE MANIÈRE POUR DIEU DE RESTER ANONYME.
Albert EINSTEIN
khoums est déconnecté   Réponse avec citation
Vieux 02/10/2018, 16h18   #2
everson29
Avatar de everson29
Pouvoir de réputation: 41
everson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond reputeeverson29 has a reputation beyond repute
Tu changes et c'est fini
everson29 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to everson29 For This Useful Post:
khoums (02/10/2018), Y.B tec (02/10/2018)
Vieux 02/10/2018, 17h40   #3
khoums
Avatar de khoums
Sérieux c'est plug and 0lay du moment la même référence ?
Envoyé de mon BLA-L29 en utilisant Tapatalk
Albert EINSTEIN
Vieux 02/10/2018, 18h01   #4
omarino
Avatar de omarino
omarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to all
Ps de codage, plug and play
Cdlt
omarino est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to omarino For This Useful Post:
khoums (02/10/2018), Y.B tec (08/10/2018)
Vieux 02/10/2018, 18h07   #5
khoums
Avatar de khoums
Merci à vous les amis
Albert EINSTEIN
Vieux 02/10/2018, 21h02   #6
rotax
Avatar de rotax
Pouvoir de réputation: 35
rotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond repute
tu as le type moteur a rentrer et taille pneumatique ...
---------- Post added at 09:02 PM ---------- Previous post was at 09:00 PM ----------
et aussi loi d'assistance mais je suis moins sure...
bref ya du télécodage a controler ou faire .
tout vient à point à qui sait attendre.
rotax est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to rotax For This Useful Post:
khoums (03/10/2018), Y.B tec (08/10/2018)
Vieux 03/10/2018, 00h54   #7
khoums
Avatar de khoums
Envoyé par rotax Voir le message
Sur citroen c2 ? T'es sur ? Avec quoi lexia ?
Albert EINSTEIN
Vieux 03/10/2018, 21h53   #8
rotax
Avatar de rotax
oui télécodage avec lexia et c'est ok, tu aura peut être besoin de rien retoucher ...
khoums (05/10/2018), Y.B tec (08/10/2018)
Vieux 05/10/2018, 02h33   #9
khoums
Avatar de khoums
Parfait. Donc aucun eeprom à dumper
Albert EINSTEIN
Erreur calculateur de suspension électronique suite à la mise à jour du calculateur DreamerCC VAS5054, VCDS, ODIS 0 06/08/2017 19h50
Fuseau horaire GMT +1. Il est actuellement 11h29.
