Recherche full backup capture 2 dci
Salut a tous je suis a la recherche d un full backup
de capture phase 2 de 2017 dci boite mécanique avec ce HW : 0281034291 ou voici les compatibilité de boitier que j ai trouver : 0281030786 0281031332 0281031387 0281031388 0281031485 0281031606 0281031644 0281031646 0281031648 0281031849 0281031867 0281031875 0281032002 0281032003 0281032004 0281032022 0281032068 0281032215 0281032226 0281032227 0281032228 0281032229 0281032312 0281032459 0281032652 0281032654 0281032809 0281032811 0281032827 0281032883 0281032885 0281032928 0281032989 0281033006 0281033119 0281033130 0281033166 0281033256 0281033358 0281033491 0281033545 0281033555 0281033721 0281033723 0281033857 0281033880 0281033885 0281033886 0281033901 0281034007 0281034052 0281034270 0281034271 0281034273 0281034291 0281034420 0281035159 0281035160 0281035165 0281035325 0281035463 0281035867 |
https://www.tlemcen-electronic.com/f...l........salut à voir
---------- Post added at 19h41 ---------- Previous post was at 19h39 ---------- Citation:
---------- Post added at 19h46 ---------- Previous post was at 19h41 ---------- Citation:
RENAULT CAPTUR 1500 90HP Code Moteur: - Marque de l'ECU: BOSCH Modèle ECU: EDC17C84 HW ECU: 0281034291 SW ECU: 10SW022501 SW Upgrade: 237612852S Étalonnage: 237612852S DAMOS: 1251_7M0 Driver: R15_01D0 ------------------------------------------------------------------------- RENAULT CAPTUR 1500 90HP Code Moteur: - Marque de l'ECU: BOSCH Modèle ECU: EDC17C84 HW ECU: 0281034291 SW ECU: 10SW022501 SW Upgrade: 237613472S Étalonnage: 237613472S DAMOS: 1251_7M0 Driver: R15_2CB6 ------------------------------------------------------------------------------ RENAULT CAPTUR 1500 90HP Code Moteur: - Marque de l'ECU: BOSCH Modèle ECU: EDC17C84 HW ECU: 0281034291 SW ECU: 10SW022501 SW Upgrade: 237610839S Étalonnage: 237610839S DAMOS: 1251_7L0 Driver: R291_501 ---------- Post added at 20h57 ---------- Previous post was at 20h54 ---------- 2 comparable avec le meme domos |
Salut il me faut un full compatible HW et boîte meca
La puissance peu importe je dois faire un essais sur un ecu pour une modification qu on a effectuer si concluant je chercherai le bon correspondant a la puissance ---------- Post added at 21h25 ---------- Previous post was at 21h23 ---------- Citation:
---------- Post added at 20h33 ---------- Previous post was at 20h30 ---------- OK tempis tu peux supprimer stp merci |
| Fuseau horaire GMT +1. Il est actuellement 19h56. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2026 DragonByte Technologies Ltd.
