#106 |
Mouais me penche de plus en plus vers le swap ecu de 6.3 à 6.1 mdr
| The Following User Says Thank You to fils For This Useful Post: | seadoo831 (02/10/2024) |
#108 |
Yes on paper seems possible
Do you have an advice to make SW compatibility like something that works Fsave or other better ? |
#110 |
No study case for moment.
Just I think how make the best SW compatibility. To have a 100-100 working car |
| The Following User Says Thank You to fils For This Useful Post: | akasa67 (07/10/2024) |
#111 |
Pouvoir de réputation: 15 ![]() ![]() ![]() ![]() |
I did programing for a guy with a citroen dispatch ecu euro6.4 2023 swap to >> euro6.2 2018
there needed to be found sw for dispatch with 6.2 and reprogram ecu , source ecu was from r8 2018 :) after all there need to rewire pins for fuel heater as 2 differ ecus but at the end worked well :) with adblue off |
#112 |
#113 |
#114 |
Avant de s occupe des fils faut gérer compatibilité sw
Gros dossier malheureusement pas donné à n importe qui :-) |
#115 | |
| The Following User Says Thank You to apol For This Useful Post: | khoums (06/11/2024) |
#116 |
Serveur is autotuner politics
Log nothing interesting ecu directly respond nack to SA |
#117 |
But that's the interesting part :) if anyone have would like to the log but pure can log not the what soft doo. :)
| The Following User Says Thank You to apol For This Useful Post: | fils (23/10/2024) |
#118 |
Ok will make you can log
#119 |
Sorry
Have try with 3 different loggers ( listen mode on off, multiple bauds ) always the flasher detect it or bus error :-( If you know exactly what config is necessary to pass under detection let me know. |
#120 |
Effectivement je les lis sans problème en BENCH avec mon KESS3 mais aujourd'hui pas de lecture calculateur protegé.
Je vais ouvrir un ticket chez alientech |
| Outils de la discussion | |
| Codage nouvelle batterie (pas VW) avec vcds | Dorvel | VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche | 16 | 02/03/2023 04h51 |
| md1CS003 | karera 1 | Programmateur de composant (flasher) | 35 | 01/11/2022 19h22 |
| Protection des cartes (PCB) avec ESD Suppresseur | ElTurco | Electronique | 5 | 14/05/2019 16h50 |
| Nouvelle clé Clio 4 avec RET | Miidjyy | programmation & synchronisation de clé | 10 | 14/02/2019 15h01 |
