Vieux 12/03/2026, 17h51   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Arrow BMW + Toyota - PSdZData Full + Lite new
Toyota
PSdZData 4.52.44 Full
PSdZData 4.52.44 Lite
BMW
PSdZData 4.58.21 Full
PSdZData 4.58.21 Lite
PSdZData is a data package required for working with electronic control units (ECUs) in BMW, Mini, Rolls-Royce, and recently new Toyota models (developed jointly with BMW, such as the Supra A90).
Here are the main differences between the Full and Lite versions:
1. What is it?
Lite version: Contains only configuration files and ECU descriptions (SWFL, CAFD, etc.). This is the "skeleton" that allows the program to see the car and change settings.
Full version: Contains everything the same, plus full firmware (SWFL, BTLD, etc.) for each ECU. This is a huge data set for a comprehensive software update.
2. Why are they needed?
Lite: Used for coding (changing hidden functions, such as disabling Start/Stop) and diagnostics. It's lightweight (usually up to 1 GB) and sufficient for 95% of everyday tasks for owners or technicians.
Full: Used exclusively for programming (flashing). If you want to update the firmware in your units to the latest version or restore a "brick" after an unsuccessful experiment, you need the full version.
Summary:
If you simply want to enable beautiful icons or disable the belt gong, download Lite. If you plan to significantly update the firmware in your units, make sure you have disk space available for the Full version.
Need it? Push buttons Rate+Thanks, PM for pass.
Type de fichier : txt BMW + Toyota - PSdZData Full + Lite new.txt (34 octets, 17 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post:
Amine-TE (12/03/2026), Brandonivo (27/07/2026), Mirsa1206 (28/03/2026), vwseb (29/04/2026)
Vieux 28/03/2026, 12h02   #2
Aleksey-MS
Lightbulb
Envoyé par Aleksey-MS Voir le message
Toyota
BMW
1. What is it?
Summary:
Need it? Push button Thanks, PM for pass | or by email right now.
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
Brandonivo (27/07/2026), youcar (02/06/2026)
Vieux 03/04/2026, 09h44   #3
Aleksey-MS
Added PSdZData 4.58.33 Full, Lite
What's new in 4.58.33:
Latest firmware: Current integration levels (I-Level) as of spring 2026.
New CAFD files: Required for programming the latest vehicles (without them, E-Sys will not read the updated ECUs and will display an error).
Bug fixes: Updated factory software to fix errors in electronic control units (ECUs).
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 02/06/2026, 19h14   #4
Aleksey-MS
Lightbulb
Toyota
BMW
1. What is it?
Summary:
Added PSdZData 4.59.30 Full, Lite.
What's new:
- Support for the latest I-Step (integration levels): Firmware and data have been updated for the latest BMW, MINI, and Rolls-Royce vehicles released up to mid-2026 (particularly relevant for the new U-series platforms and I-series electric vehicles).
- Updated CAFD files: New files have been added for coding modules. If you attempt to code a new vehicle using old databases, the software E-Sys will display a CAFD missing error or show trimmed parameters without descriptions.
Vieux 16/06/2026, 18h29   #5
Aleksey-MS
Lightbulb
Toyota
BMW
1. What is it?
Summary:
Added new versions - PSdZData 4.59.40 Full, Lite.
Vieux 09/07/2026, 17h12   #6
Aleksey-MS
What's new in BMW PSdZData 4.60.11
* New I-Step (26-07): Integration levels have been added for programming vehicles starting in July 2026 (e.g., S18A-26-07-xxx).
* Database Update: The latest firmware and coding files (SWFL, BTLD, CAFD) for current body styles (G60, G90, U- and I-series).
* DME Lockouts: No new restrictions; flashing software from higher trim levels works as expected.
Vieux 15/08/2026, 17h16   #7
Aleksey-MS
What's new in BMW PSdZData 4.60.42
Vieux 20/11/2026, 20h17   #8
Aleksey-MS
Whats New in BMW PSdZData
- Dataset Release: Bumped the BMW branch up to 4.62.32 (both Full and Lite versions); Toyota stays at v4.60.42.
- Updated I-Levels: Includes fresh November 2026 ECU firmware, bootloaders, and coding files for F, G, I, and new NA-series vehicles.
- Usage Note: Lite version remains lightweight for everyday FDL/VO coding, while the Full archive contains complete flash data for ECU programming.
BMW PSdZData 4.30.33 Lite - Mega Aleksey-MS BMW, Mini, Rolls-Royce 46 12/03/2026 17h53
BMW PSdZData 4.35.10 Lite - Torrent (without pass) Aleksey-MS BMW, Mini, Rolls-Royce 5 26/07/2022 15h17
BMW E-Sys3.28.1, E-Sys Launcher Prem. 2.7.0, Psdzdata V3.61.1 Lite Nyckos BMW, Mini, Rolls-Royce 0 06/03/2018 10h54
PSdZData v.4.10.13 - Lite et Full Nyckos BMW, Mini, Rolls-Royce 2 06/03/2018 10h25
BMW E-sys PSdZdata Lite 4.10.13 Nyckos BMW, Mini, Rolls-Royce 0 06/03/2018 10h24
Fuseau horaire GMT +1. Il est actuellement 21h17.
