Discussion fermée
Vieux 09/02/2014, 09h58   #1
baste59
Avatar de baste59
baste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to beholdbaste59 is a splendid one to behold
Par défaut Unlocker continental Simos PCR2.1
logiciel pour décode les calculateur continental Simos PCR2.1
mots de passe par pm
Type de fichier : rar PCR2.1 Unlocker 1.0.rar (15,7 Ko, 190 affichages)
baste59 est déconnecté
The Following 40 Users Say Thank You to baste59 For This Useful Post:
Acidboy (17/05/2014), alamelou (06/04/2015), Auto16 (21/05/2014), autoscan (16/05/2014), BAZBOZ (10/03/2014), birdy85 (10/02/2014), boss97470 (20/03/2014), CSYSTEME (20/11/2014), diagprog (17/05/2014), eros0673 (03/06/2014), fayssal2017 (13/06/2024), filou2411 (12/03/2014), fruky (07/05/2015), hamiza (14/04/2021), jaed63 (23/10/2014), jah83 (09/02/2014), jpanasonic (09/02/2014), jpay2 (16/05/2014), Jul971 (03/04/2015), khaledk (21/05/2014), Mrpromega (20/05/2014), nasisamy (11/02/2021), nitrocircus (19/11/2021), nizar (17/05/2014), nyaiko (11/02/2018), pikachuvstr (10/01/2024), pp08 (04/08/2019), Race84 (20/05/2014), rosco2012 (29/01/2015), Sabrijam1 (28/07/2020), SimOoO (06/07/2014), sphynx (02/06/2014), sylvain02120 (09/02/2014), The_devil_Withe (19/05/2014), Truc (03/06/2018), vortex (10/03/2014), wahye (16/03/2014), youcef_trik (27/04/2019), youyouteam9874 (23/02/2014)
Vieux 10/03/2014, 20h22   #2
BAZBOZ
Avatar de BAZBOZ
BAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of lightBAZBOZ is a glorious beacon of light
Si ca marche, j'avoue que c'est un beau travail, merci baste59
BAZBOZ est déconnecté
Vieux 10/03/2014, 20h50   #3
jojo1212
Avatar de jojo1212
jojo1212 is an unknown quantity at this point
merci beaucoup
jojo1212 est déconnecté
Vieux 20/05/2014, 00h00   #4
The_devil_Withe
Avatar de The_devil_Withe
The_devil_Withe is on a distinguished road
Et avec un GQ-4x Willem programmeur on peux la lire écrire cette eeprom pour unlocker?
The_devil_Withe est déconnecté
Vieux 20/05/2014, 00h18   #5
MCNexo94
Avatar de MCNexo94
Salut Baste59 ques tu entend par décoder ?? mettre a l'état VIERGE, ou OFF, ou débloquer l'eprom a fin de reprogrammer la partie cartographie moteur ?
MCNexo94 est déconnecté
Vieux 20/05/2014, 01h55   #6
Kennfeld
Avatar de Kennfeld
rien à voir avec du off ou du virgin
unlocker sert a deverrouiller le flashage par la prise des tdi 1600
d'origine il est uniquement possible de les flasher avec un fichier approuvé rsa par vag ...
en fait unlocker réactive le flash par la prise par les outils tiers
Kennfeld est déconnecté
The Following User Says Thank You to Kennfeld For This Useful Post:
Maxpower (20/05/2014)
Vieux 20/05/2014, 07h52   #7
MCNexo94
Avatar de MCNexo94
OK c bien ce que je penser mais le KESS le fait déjà ça ;)
The Following User Says Thank You to MCNexo94 For This Useful Post:
angeflasheur (20/05/2014)
Vieux 21/05/2014, 00h08   #8
The_devil_Withe
Envoyé par baste59 Voir le message
il y a aussi le unlocker en version 1.1
personne ne la?
quelle différence? il y a le simos 8.x en plus on dirait.
Vieux 08/11/2016, 19h13   #9
karera 1
Avatar de karera 1
bonsoir a tous je dois faire un egr off sur un simos pcr 2.1 quel metthode et la plus simple dans un premier tant pour le debloquer enssuite une fois debloquer et il possible d'extraire la cartho par kess obd ?
karera 1 est déconnecté
Vieux 08/11/2016, 19h20   #10
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
Salut il faut ouvrir ton ecul et le débloquer avec le programme adéquat km tech avez fait un soft pour ça il est sur le forum crdl
Pas de Thank's plus d aides
seadoo831 est déconnecté
Vieux 08/11/2016, 19h23   #11
karera 1
Avatar de karera 1
j'ai vue qu'il etait possible de travailler directement sur l'eprom mais pour ca il faut decoller le circuit ce que je prefere evite sinon rique de plier la carte car l'eprom se trouve face du dessous je sais que il y a pcr2.1 unlocker mais je prefere me rensseigner avant de faire une connerie j'ai vue plusieur poste sur laquel ca a planter des voiture qui ne demarre plus !
Vieux 08/11/2016, 19h25   #12
karera 1
Avatar de karera 1
en gros je cherche une method deja tester et reussi j'ai pour ca fgtech v54 kess ktag gq4x xprog etc mais je demande la methode operationnel !
Vieux 08/11/2016, 19h28   #13
karera 1
Avatar de karera 1
les resistances qui sont a placer en les passerelle sont elle obligatoire ou non ce que l'ont met sur le circuit ?
Vieux 08/11/2016, 19h29   #14
karera 1
Avatar de karera 1
un tuto ca aurais ete nickel de la part d'un membre qui aurais reussi !
Vieux 08/11/2016, 19h40   #15
karera 1
Avatar de karera 1
j'ai trouver cette video mais je n'est pas de resistance sous la main et il vraiment necessaire d'utiliser cette resistance jusqu'a maintenant tous les schema que j'ai pus faire sur les calculateur qui montrait des resistance persso j'ai jamais utiliser et c'etait toujour nickel donc laj'ai le doute comme c'est un calculateur tres chiant a faire simple pour ceux qui l'ont deja reussi bien sur !
https://www.youtube.com/watch?v=AaTfyDa4OCo
Discussion fermée
CarProTool Ford Sony Visteon Car Radio Unlocker [TMS470] CPT CarProTool Programmer 1 09/12/2013 17h04
simos pcr2.1 galletto v53 stef38140 Programmateur de composant (flasher) 0 09/05/2013 13h05
Motorolla unlocker for s912 pecirepi Programmateur de composant (flasher) 1 11/04/2009 20h25
Fuseau horaire GMT +1. Il est actuellement 20h20.
