Vieux 13/12/2016, 07h05   #16
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I would appreciate if the site Administrator would change the thread title from v8.37 to v8.38 and attach the file "APP_Update _835-838.txt" to the first post.
Please add this paragraph as well:
APP_Update_835-838.EXE should be attempted if you have a working "APP-835.7z" implementation or APP-8.37 upgrade. It will update Lexia and PP2000 to versions 500.74 and 600.80 respectively, with latest fixes and support level.
Type de fichier : txt APP_Update _835-838.txt (262 octets, 59 affichages)
Simple est déconnecté   Réponse avec citation
Vieux 13/12/2016, 12h25   #17
nikita
Avatar de nikita
nikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the roughnikita is a jewel in the rough
hi simple
maj for me it's no ok
error maj si problème persiste contacter la hotline
nikita est déconnecté   Réponse avec citation
Vieux 13/12/2016, 14h15   #18
Simple
Avatar de Simple
DiagBox has either tried to connect and blocked the software or files were not over written properly due to the processes were not all killed before the update process.
Disconnect the network, restore your APPDIAG.SYS and start DiagBox again as Administrator.
Vieux 13/12/2016, 19h07   #19
nikita
Avatar de nikita
When I restart diagbox I have an error message now missing .dll ect
Tomorrow I reinstalled the update to see if everything comes back ok
Vieux 13/12/2016, 19h43   #20
Simple
Avatar de Simple
Hi nikita,
can you give more information about your installation, maitresox reported that update 8.38 fail to upgrade DiagBox systems installed on Windows XP!!
However, Some errors will result in deleting the contents of the "C:\AWRoot\bin\fi\cache" folder, if that has happened, DiagBox will fail to start. Ensure you have at least the 13 files starting with "fr.actia.AWF.xxxx.dll".
If that has happened to you, then download the "Cache Contents Restorer" (a link is available in the attachment within the DiagBox 8.01 Installation (updated) post).
Users already reported successful upgrade to v8.38, but they complain that DiagBox version number does not change. Please notice that this is an upgrade to Lexia and PP2000 and not DiagBox. Hence DiagBox version will NOT be changed as a result of this upgrade.
Good luck. Simple..
Vieux 14/12/2016, 07h43   #21
nikita
Avatar de nikita
Hello Simple
My windows 7 32 bits I have difficult to perform the maj I will start again this morning
Vieux 14/12/2016, 12h25   #22
nikita
Avatar de nikita
Envoyé par Simple Voir le message
Hi nikita,
Good luck. Simple..
hi Simple
Maj ok now thanks you
bye bye
Vieux 14/12/2016, 13h50   #23
Simple
Avatar de Simple
Well done nikita,
May be you could explain how was the problem caused and how did you solve it, so that other users may learn from it.
Regards, Simple.
Vieux 14/12/2016, 20h03   #24
nikita
Avatar de nikita
Well done nikita,
Regards, Simple.
Hello Simple
I reboot the kill psa relaunch the update and it pass without worry
Vieux 17/12/2016, 23h16   #25
morpheus70
Avatar de morpheus70
morpheus70 is on a distinguished road
Quelle version de Windows doit on avoir pour utiliser cette mise à jour?
Je suis sous XP ma tablette est une VILIV
morpheus70 est déconnecté   Réponse avec citation
Vieux 18/12/2016, 09h32   #26
nikita
Avatar de nikita
Envoyé par morpheus70 Voir le message
moi je suis sur W7 32 bits et comme la mentionner plus maitresox les nouvelles mises a jours avec XP c'est fini
Vieux 18/12/2016, 17h49   #27
morpheus70
Je vais réinstaller Windows 7 sur un autre PC.
Merci pour les réponses.
Vieux 19/12/2016, 11h10   #28
Larson92
Avatar de Larson92
Apres installation de la mise a jour j'ai un message d'erreur au démarrage qui me dit que java n'est pas disponible pour lancer l'application sim, pas de machine virtuelle trouvé dans jre7/bin
quelqu’un pour une solution?
Le savoir n'est rien si le savant n'a pas la noblesse de le partager...
Vieux 21/12/2016, 21h41   #29
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Envoyé par Larson92 Voir le message
Salut, tu peux désinstaller et recommencé l'ami...
J'ai eu la même erreur récemment car j'ai formater mon pc et réinstaller . J'ai eu ce message.
J'ai re désinstaller et recommencé, et maintenait c'est ok.
C'est les joies de l'informatique !
Envoyé de mon ASUS_Z00AD en utilisant Tapatalk
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 22/12/2016, 16h32   #30
Larson92
Avatar de Larson92
Merci pour ta réponse, quand tu parles de désinstaller, c'est tout diagbox? ou seulement la mise a jour???
Lexia & PP2000 (from DiagBox 8.35) Simple LEXIA, PP2000, DiagBox 63 25/11/2018 22h25
Quoi faire avec le xs evolution sous diagbox , pp2000, lexia ishams2002 LEXIA, PP2000, DiagBox 7 14/11/2014 19h56
cherche logiciels diagbox, lexia et pp2000 originale beka1975 LEXIA, PP2000, DiagBox 1 20/11/2013 23h06
Peugeot/Citroen DIAGBOX PP2000 LEXIA bloker LEXIA, PP2000, DiagBox 7 30/10/2013 07h27
Fuseau horaire GMT +1. Il est actuellement 19h03.
