Vieux 20/03/2019, 14h55   #1
Volik8
Avatar de Volik8
Volik8 is an unknown quantity at this point
Par défaut citroen
Hello, you need to disable the immobilizer on Citroen, can someone help?
ecu bosch edc17c10
Type de fichier : rar citroen immo.rar (932,4 Ko, 8 affichages)
Dernière modification par Volik8 ; 20/03/2019 à 17h07.
Volik8 est déconnecté   Réponse avec citation
Vieux 20/03/2019, 15h00   #2
zouaoui mohamed
Avatar de zouaoui mohamed
Hi post your file you can help
Vieux 20/03/2019, 17h08   #3
Volik8
Avatar de Volik8
Help guys please !!!
Vieux 21/03/2019, 10h04   #4
Volik8
Avatar de Volik8
Hello !! Can someone help
Vieux 21/03/2019, 12h54   #5
yann3
Avatar de yann3
Pouvoir de réputation: 66
like that and go back
forget not thank you
paas ,mp
Type de fichier : rar citroen immo.MPC_FLASH_OFF.rar (932,5 Ko, 3 affichages)
Volik8 (21/03/2019)
Vieux 21/03/2019, 16h38   #6
Bemich
Avatar de Bemich
Pouvoir de réputation: 9
Bemich will become famous soon enough
Please post Résulta Volik8
Bemich est déconnecté   Réponse avec citation
Vieux 22/03/2019, 11h31   #7
Volik8
Avatar de Volik8
Hello colleagues, the car started but there is a problem, the bsi unit does not understand that the car is running, and the wipers do not have anything working ...
there is an error in the bsi block by immobilizer, please correct the dump bsi
Type de fichier : bin immo citroen bsi 95128 stok.BIN (16,0 Ko, 2 affichages)
Vieux 22/03/2019, 12h01   #8
yann3
Avatar de yann3
Hi, I do not see the relationship between ecu engine and bsi
when making an ecu immobilizer, do not touch the bsi.
the problem is probably
Vieux 22/03/2019, 13h31   #9
kitopa
Avatar de kitopa
kitopa will become famous soon enoughkitopa will become famous soon enough
Volik8 your problem was the BSI i guess. When there is communication problem, the BSI stay in economy mode, and even if the car is running, the BSI don't see that. Check wires, and consider changing BSI.
kitopa est déconnecté   Réponse avec citation
Vieux 23/03/2019, 08h40   #10
yann3
Avatar de yann3
Hi
the car did not start after a worry bsi, probably.immo off put the engine back into operation, but can not do anything for the bsi.
you have to change the bsi and you swap eeprom
la voiture ne demarrait pas suite a un soucis bsi,probablement.l´immo off a remis le moteur en fonctionnement ,mais ne peut rien pour le bsi.
il faut que tu change le bsi et tu swap l´eeprom
Vieux 28/03/2019, 15h32   #11
Volik8
Avatar de Volik8
Envoyé par kitopa Voir le message
Hello to all !!
Replaced BSI The problem remained !!!
BSI does not see the engine running, BSI remains in economy mode.
Electric power steering also does not work.
The battery charging light is on when the engine is running. Errors in the engine control unit
U1401
U1218
U1213
What to do???
Vieux 29/03/2019, 07h53   #12
yann3
Avatar de yann3
Hi
control the bus can h and ldu abs box, surely him that prevents communication between bsi, engine ECU and power steering.
so shunt the can h and l of the abs case
---------- Post added at 08h53 ---------- Previous post was at 08h52 ----------
Hi
control bus can h and l of the abs box, surely it prevents communication between bsi, engine ECU and power steering.
Vieux 29/03/2019, 11h53   #13
yann3
Avatar de yann3
as said ggvaniou, you will need the eeprom too
https://www.tlemcen-electronic.com/f...ad.php?t=81606
Vieux 30/03/2019, 11h03   #14
mexicain
Avatar de mexicain
mexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to behold
Hello test
Type de fichier : rar citroen immo_immo_off.rar (938,5 Ko, 1 affichages)
mexicain est déconnecté   Réponse avec citation
pin bsi jc citroen brahim chafa3 Transponder, code pin 1 31/03/2018 22h21
Citroen dumps immo off tested for citroen 100/100 ok lassad Immobilizer dumps/solutions 0 14/01/2016 14h18
citroen c3 1.1 autodiagnos kamal Transponder, code pin 2 22/03/2013 21h10
Citroen Lexia 347.19 + Citroen C5 2001-2008 Multilingual TAGRART LEXIA, PP2000, DiagBox 0 16/11/2012 16h48
citroen c2 thepatrick31 Airbag 1 11/04/2010 18h38
Fuseau horaire GMT +1. Il est actuellement 00h00.
