Vieux 26/04/2021, 12h14   #16
fufounet
Avatar de fufounet
fufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant futurefufounet has a brilliant future
deja fait->pareil
Vieux 26/04/2021, 12h42   #17
Pouvoir de réputation: 265
a mince dommage jai pas fais de capture de celle que jai faite part contre moi javais bien le contacteur a a cle dans la porte passager et celui la si tu mets sans pareil..
fufounet (26/04/2021)
Vieux 26/04/2021, 15h22   #18
Pelican
Avatar de Pelican
Pelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant future
Sinon tu te procure le shema,
Et tu remai tes fils ou il faut du premier coup
Envoyé de mon PRA-LX1 en utilisant Tapatalk
Pelican est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to Pelican For This Useful Post:
akasa67 (26/04/2021), fufounet (26/04/2021)
Vieux 26/04/2021, 16h33   #19
ozilmlk
Avatar de ozilmlk
ozilmlk is a splendid one to beholdozilmlk is a splendid one to beholdozilmlk is a splendid one to beholdozilmlk is a splendid one to beholdozilmlk is a splendid one to beholdozilmlk is a splendid one to beholdozilmlk is a splendid one to behold
Salut prend le schema électrique, tu pourras pas te tromper avec.
Cordialement
Que chacun apporte sa contribution et devienne le bâtisseur d'un monde fondé sur l'entraide.
ozilmlk est déconnecté   Réponse avec citation
The Following User Says Thank You to ozilmlk For This Useful Post:
Vieux 26/04/2021, 16h45   #20
fufounet
Avatar de fufounet
oui c est sur le schema serait mieux....
juste un truc a propos du contacteur pour neutraliser l airbag passager
en fait celle ci n en a pas
MAIS
lorsque je le code sur "SANS"
et ben ca me donne un erreur de codage (un defaut en plus)
je me demande si c est la bonne ref d ecu d airbag...
d autant plus que le vin n etait pas le bon et je l ai recodé avec ret....
---------- Post added at 02:44 PM ---------- Previous post was at 02:42 PM ----------
en fait la ref serait 8200375763
mais comme pa
---------- Post added at 02:45 PM ---------- Previous post was at 02:44 PM ----------
je disais comme parfois il y a un A ou un B...
Vieux 27/04/2021, 10h54   #21
fufounet
Avatar de fufounet
merci a ceux qui m on aidé.
finalement j ai sorti ddt2000
j ai fais un raz complet
puis tout recodé
je pense que le probleme venait de cette condamnation par clef de l airbag passager.
la voiture n avait pas ce contacteur
mais quand je codait "SANS" avec clip ,defaut en plus direct
donc ddt2000 m a sorti de la panade
ps ma reprisde des fils coupés etait bonne
The Following 3 Users Say Thank You to fufounet For This Useful Post:
akasa67 (27/04/2021), ozilmlk (27/04/2021), redoneraji (04/01/2022)
clio anti-demarrage clio 2 zorg Renault, Dacia, Nissan 19 11/10/2022 10h23
Clio 2 phase 1 1.9d 35 clio 2 1.5 dci soucis antidémarrage habib87 Immobilizer dumps/solutions 22 24/01/2017 20h52
moteur clio 1 sur clio II technicien Mécanique générale 3 25/11/2014 13h03
Fuseau horaire GMT +1. Il est actuellement 19h18.
