13/01/2019, 14h16 | #31 | |
Pouvoir de réputation: 75 |
il existe deja! "sinon il y a un paquet d'outils qui le permette." => interressant allez, la suite en privé ou rien. @+ |
The Following 14 Users Say Thank You to MrRorry For This Useful Post: | Alilouf (11/04/2019), atlon2 (14/01/2019), autodiagauto (16/03/2019), doud77 (13/01/2019), guyguy307 (24/02/2019), HRMNKY (23/01/2019), j-sky (13/01/2019), jean-marc 10 (23/02/2019), jphp (13/01/2019), kam306 (13/01/2019), nasisamy (12/03/2019), samy (20/03/2019), Y.B tec (13/01/2019), yann3 (13/01/2019) |
23/02/2019, 04h03 | #32 |
Pouvoir de réputation: 0 |
Bonjour a tous,
je suis a la recherche de la fameuse version diagbox 9.23 cracké de MrRorry si quelqu'un peut m'aider pour la télécharger u me dire comment l’obtenir en vous remerciant d'avance VRROOOMMMMMMMMMMM |
23/02/2019, 07h56 | #33 |
Pouvoir de réputation: 31 |
Pour cela il faut contacter MrRorry ,lui seul a les clés du camion !lol
Veuillez donner suite à votre diag et à la résolution du problème !! un petit merci ne coûte rien . |
The Following 4 Users Say Thank You to adiago For This Useful Post: |
24/02/2019, 14h46 | #34 |
Pouvoir de réputation: 7 |
Hello,
I am currently working with the DIABOX V07.82 (Maitresox) and still have a laptop with the DIAGBOX V07.57 (Scary). Both laptops are powered by an original VCI (A1281Z and 9780Z5). Operating system is Windows XP Sp3 prof. So far I have installed the ISO with Virtual Clone. I would like to reinstall the DIAGOX V09.23 from MrRorry on a laptop with WIN7 32 bit and buy the activation of MrRorry. Ask: 1. Which additional programs are needed? So far the V07.82 Java7; Vc ++ 2008; NetFrameWork 3.5 Sp1. 2. Does MrRorry provide the activation code, software and installation instructions? 3. Is there an installation video for the V09.23 from MrRorry? 4. Is WIN7 32 bit the cheap operating system or is it better to use XP Sp3 prof? 5. How do I reach MrRorry - the PM? Thanks for help and answers. Greeting Wolfgang |
16/03/2019, 13h12 | #35 | |
16/03/2019, 13h24 | #36 |
Pouvoir de réputation: 249 |
salut , plus tu avance en version a jours et moins tu as de codages disponibles off line !!
codage manuel !! exemple tu peux coder un remplact embrayage complet sur un C 5 X7 avec une version 7.02 mais pas avec une version 8.50 !!! @ |
03/04/2019, 18h32 | #37 |
Je confirme pour la version de MR Rorry, elle fonctionne super bien sur une C3 (B618) de 2018. Alors aller plus loin en version ... Pas encore testé si des télécodages étaient présent. Ce week-end surement. Je vous tiens au courant. P.S. : encore merci MrRorry et enchanté d'apprendre que cette version fonctionne en 64Bits, moi qui me suis acharné à remonter un Win7 32bits A+ |
PSA DiagBox 9.12 (officiel ) | roony75 | Peugeot, Citroën | 13 | 15/01/2019 02h57 |
Recherche diagbox et sonde officiel | ptidemon | LEXIA, PP2000, DiagBox | 14 | 03/02/2016 21h06 |
vag com officiel | SM78 | VAS5054, VCDS, ODIS | 3 | 08/04/2014 19h09 |
