04/11/2019, 11h10 | #16 |
Pouvoir de réputation: 14 |
slt lami voila off sur flash fais retour ;)
The Following 2 Users Say Thank You to Tof02770 For This Useful Post: | ggvaniou (04/11/2019), television (04/11/2019) |
04/11/2019, 11h15 | #17 | |
Pouvoir de réputation: 25 |
apparemment il a pas capter je crois lemp il voulait dire le mp (mot de passe)loll
On a souvent besoin d'un plus petit que soi |
The Following 2 Users Say Thank You to soustourou For This Useful Post: | ggvaniou (04/11/2019), television (04/11/2019) |
04/11/2019, 11h51 | #18 |
Pouvoir de réputation: 37 |
MERCI LES AMIS
je test dans l après midi ,je vous tiens au courant cdl
x17officiel kess ktag v54, delphi officiel ,multidiag,ms908pro officiel,flex oficiel.vente fichiers |
The Following User Says Thank You to television For This Useful Post: | ggvaniou (04/11/2019) |
04/11/2019, 12h15 | #19 |
Pouvoir de réputation: 30 |
ok soustourou
..... apparemment oui ....... mais le hik c'est moi ki devient analphabète ....apparemment tri-langue aussi ! ! ! salutations l'ami |
The Following 2 Users Say Thank You to aza For This Useful Post: | ggvaniou (04/11/2019), soustourou (05/11/2019) |
04/11/2019, 12h38 | #20 |
PAS DÉMARRAGE !!merci qaud meme
---------- Post added at 13h38 ---------- Previous post was at 13h30 ---------- pas démarrage merci
04/11/2019, 12h41 | #21 |
Pouvoir de réputation: 81 |
Essaie mon fichier ,ca va fonctionner ;)
---------- Post added at 16h40 ---------- Previous post was at 16h38 ---------- Ton problème est ailleurs. Sinon tu as ton pin d origine? ---------- Post added at 16h41 ---------- Previous post was at 16h40 ---------- Et post ta référence d origine stp?
The Following User Says Thank You to ggvaniou For This Useful Post: | Y.B tec (05/11/2019) |
04/11/2019, 12h59 | #22 | |||
pas de démarrage merci
---------- Post added at 13h49 ---------- Previous post was at 13h47 ---------- Citation:
HUJR merci ---------- Post added at 13h50 ---------- Previous post was at 13h49 ---------- Citation:
---------- Post added at 13h59 ---------- Previous post was at 13h50 ---------- Citation:
code oin bsi NN28
04/11/2019, 13h16 | #23 |
Ok je t envoie ca dans un instant
The Following 3 Users Say Thank You to ggvaniou For This Useful Post: |
04/11/2019, 13h29 | #24 |
Pouvoir de réputation: 18 |
voici ton off avec pin ori |
The Following User Says Thank You to redou28 For This Useful Post: | television (04/11/2019) |
04/11/2019, 13h34 | #25 |
Voila ton eprom recodé
The Following User Says Thank You to ggvaniou For This Useful Post: | television (04/11/2019) |
04/11/2019, 13h36 | #26 |
Slt les amis en mais les points sur le i ok
Déjà ce off sur eeprom ou flash prq bcp qui envoie eeprom autre envoie flash du cou l'ami qui cherche solution il es perdu lol Donc ma question ce off ce fais sur quelle partie merci les amis ;) |
The Following User Says Thank You to Tof02770 For This Useful Post: | television (04/11/2019) |
04/11/2019, 13h39 | #27 |
fais juste attention ,si le sw est le même et hw différent.
l adresse tu pin peut être différent ,si c est différent ca fonctionnera pas ---------- Post added at 17h39 ---------- Previous post was at 17h38 ---------- j ai deja testé plusieurs off sur eprom ,cela fonctionne.
04/11/2019, 14h54 | #28 |
ce calculo commence a me prendre le choux, pourtant avec ce fichier ,elle démarre , mais pas dea pas de ventilation aire abs default et quand je coupe le moteur redemarre que si je debranche et rebranche le calculo !!!!!!!je poste le fichier si quelqun a une idée ,je suis bien sur preneur .edc17c10 demarage ok.rar
04/11/2019, 14h58 | #29 |
Tu as essayé quel fichier?
---------- Post added at 18h58 ---------- Previous post was at 18h57 ---------- Pourquoi pas le cloner directement?
04/11/2019, 15h13 | #30 | |
The Following User Says Thank You to television For This Useful Post: | pp08 (05/11/2019) |
Sponsored Link |
Liens sociaux |
Discussions similaires | ||||
Edc17c10 | Sonezis | Chiptuning | 14 | 21/05/2021 02h37 |
EGR off EDC17c10 PSA | verbatime | Chiptuning | 25 | 02/12/2020 17h18 |
off edc17c10 | KKHALIL | Immobilizer dumps/solutions | 16 | 11/08/2018 11h53 |
edc17c10 | karera 1 | Réparation & Programmation des calculateurs | 13 | 01/05/2015 12h23 |
Edc17c10 psa | dafit906 | Immobilizer dumps/solutions | 5 | 10/02/2015 19h20 |
