slave
Vieux 05/10/2011, 16h53   #1
reda75
Avatar de reda75
Pouvoir de réputation: 41
reda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond reputereda75 has a reputation beyond repute
Thumbs up Renault Clip V112 08.2011 Multilanguage
1. If you already have an earlier version, make sure deinstall previous version!
2. Restart your computer
3. Run Crack.reg
4. When you install, when asked the country to select OTHER.
5. Installed, restart your computer
6. After rebooting the screen will be registered.
7. First: Alt + Ctrl + Del and in the process disable RSRWin.exe
8. Go to the Windows folder and delete the file RSRWin.exe
9. Through regedit to erase all the lines in the registry file RSRWin.exe
10. Reload
ps. when will a bug when running in the archive is to replace the two other files.
Open the Registry Editor and Regestry find in it the following branch:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Nls/CodePage/
In it we find the lines 1250 and 1252, click on them, right-click and change the value to c_1251.nls. After this, restart your computer to the new values to take effect.
Everything will be ok
http://dtwcft.1fichier.com/CLIP112_0_0_0.7z.008
http://gqqpsy.1fichier.com/CLIP112_0_0_0.7z.007
http://irug18.1fichier.com/CLIP112_0_0_0.7z.006
http://ota999.1fichier.com/CLIP112_0_0_0.7z.005
http://dzopmt.1fichier.com/CLIP112_0_0_0.7z.004
http://rerowk.1fichier.com/CLIP112_0_0_0.7z.003
http://xsn9t5.1fichier.com/CLIP112_0_0_0.7z.002
http://bv311n.1fichier.com/CLIP112_0_0_0.7z.001
PASS softnco
reda75 est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to reda75 For This Useful Post:
Aimadfm (08/10/2011), beonce (06/10/2011), solution auto (05/10/2011), sosauto (05/10/2011)
Vieux 06/10/2011, 00h13   #2
beonce
Avatar de beonce
can you delete the password those interested by the software to ask you to deprive
Renault Diagnostic Can-Clip v110 (05/2011) Multilanguage ramaz Renault, Dacia, Nissan 10 19/01/2012 02h09
Renault Clip V112 adiago Renault, Dacia, Nissan 3 07/09/2011 22h44
Renault Clip v111 (07/2011) Multilanguage mecatronique Renault clip, DDT2000, Nissan consult 0 07/09/2011 16h08
Fuseau horaire GMT +1. Il est actuellement 11h46.
