Vieux 10/12/2019, 11h06   #3361
gabigafu
Avatar de gabigafu
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
non, il faut une carte valide pour apprendre le lecteur.
gabigafu est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to gabigafu For This Useful Post:
BILAUTO (10/12/2019), ecutech (10/12/2019), Ilyas1 (10/12/2019), multi290 (11/12/2019), pouettedu76 (10/12/2019), Xav (11/12/2019)
Vieux 11/12/2019, 08h39   #3362
Pelican
Avatar de Pelican
Pelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant futurePelican has a brilliant future
Bravo, Oui très bonne maj !
Je vais donnez ma liste de souhaits pour Noël.
Est ce que c est possible de bosser sur:
les double de megane et scenic 3 2016+.
Pour ma part les double suffise !
Et les vierge des ecm abs... Total et remettant les kilomètres à 0 dans le but de mettre de l occase sur des vehicule qui ont plus de 8 ans.
Après pour l adaptation si ont peut reprogrammé dans le réseau Renault.
Merci gabi
Et bonne continuation
The Following 7 Users Say Thank You to Pelican For This Useful Post:
gabigafu (11/12/2019), Ilyas1 (11/12/2019), klif26 (11/12/2019), kosmyn (11/12/2019), multi290 (11/12/2019), pouettedu76 (11/12/2019), Scanworld2020 (12/12/2019)
Vieux 11/12/2019, 10h56   #3363
lolo64
Avatar de lolo64
lolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to behold
Pour l'ABS il y a bien une fonction dans ddt (jamais testé).
Cdt.
Type de fichier : jpg Remise de calculateur en l'état vierge.jpg (97,4 Ko, 102 affichages)
lolo64 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to lolo64 For This Useful Post:
E46 (15/12/2019), Pelican (11/12/2019)
Vieux 11/12/2019, 11h06   #3364
skeuf
Avatar de skeuf
Pouvoir de réputation: 66
Il me semble que sa fonctionne uniquement si bloc neuve avec moin de 50 ou 100km sinon sa fonctionne pas
Attend quand même confirmation
En plus si cette maj sort ce n'est pas le changement de bloc abs pour cause de panne qui va intéressez la plupart mais plutôt accès à l'eeprom en relation avec le dash
Envoyé de mon VOG-L29 en utilisant Tapatalk
The Following 3 Users Say Thank You to skeuf For This Useful Post:
duroi (14/12/2019), jah83 (11/12/2019), Pelican (11/12/2019)
Vieux 11/12/2019, 12h18   #3365
Ilyas1
Avatar de Ilyas1
Ilyas1 is on a distinguished road
Envoyé par JulienP Voir le message
Merci gabi
Mégane 4 et Scenic 4 tu veux dire, c'est ça? Ça serait magnifique
Sent from my TA-1021 using Tapatalk
Ilyas1 est déconnecté   Réponse avec citation
The Following User Says Thank You to Ilyas1 For This Useful Post:
Vieux 11/12/2019, 12h40   #3366
Pelican
Avatar de Pelican
Oui le probleme de c est que c'est proteger exprès !(normal)
Sauf pour la personne qui veux juste remplacer la pièce pour une vrai panne.
Et megane 3 et scenic 3 2016 +c est déjà bien!
Mais en vrai je m'en sert pas tout les jour de renolink mais c est bien pratique sur des veilles auto pour adapter de l occasion que ça soit uch, frein de parking ou multimédia.
En prenant sont temp on arrive à ce débrouiller et dépanner des véhicule.
Moi je suis bien heureux de l avoir ma caisse à outils.
Vieux 11/12/2019, 18h24   #3367
profrenault
Avatar de profrenault
profrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant future
Salut gabigafu
jespere que tu vas bien
serait il possible que tu rajout option vierge UCH clio 4 coté Radio fréquence des cartes
si tu as besoin d'un UCH pour test j'ai 3 (via team)
La vrais vie est dans le partage expérience. Clip/DDT2000/VAG COM /FGTECH OFFICIEL/
profrenault est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to profrenault For This Useful Post:
Alessiapia14 (20/12/2019), BILAUTO (11/12/2019), Pelican (11/12/2019), pouettedu76 (11/12/2019), progdebutant (12/12/2019)
Vieux 14/12/2019, 21h41   #3368
auto_tech
Avatar de auto_tech
auto_tech will become famous soon enough
salut @ tous
svp qui as reussi a faire reset par obd pour une dae clioIII avec renolink par obd ou sur table parceque j n'arive pas a le faire toujours error can c'est une dae de la casse celle de la voiture est hs
auto_tech est déconnecté   Réponse avec citation
Vieux 14/12/2019, 22h05   #3369
belle-palestine
Avatar de belle-palestine
belle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant futurebelle-palestine has a brilliant future
Envoyé par auto_tech Voir le message
salut @ tous
Salut fais plusieurs fois, normalement ça passe tout seul, t as essayé une version différente de la tienne ?
belle-palestine est déconnecté   Réponse avec citation
The Following User Says Thank You to belle-palestine For This Useful Post:
autodiagauto (28/11/2021)
Vieux 14/12/2019, 22h18   #3370
belle-palestine
Regarde si tu as bien du 12V sur les deux gros fils si le 12V arrive ta nouvelle DAE a surement un problème.
Avec renolink
Extra / EPS virginiser / Clio 3,Modus / Connect / Clear Immo Code / Disconnect
The Following 2 Users Say Thank You to belle-palestine For This Useful Post:
autodiagauto (28/11/2021), auto_tech (16/12/2019)
Vieux 14/12/2019, 22h30   #3371
duroi
Avatar de duroi
duroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to beholdduroi is a splendid one to behold
Il te faut normalement une résistance de 120ohm en le hi et lo du can.
The Following 2 Users Say Thank You to duroi For This Useful Post:
auto_tech (16/12/2019), gabigafu (15/12/2019)
Vieux 16/12/2019, 11h57   #3372
auto_tech
Avatar de auto_tech
Envoyé par duroi Voir le message
meme avec resistance sur table ERROR CAN et par obd NO DATA
probleme resolu avec carprog lecture et ecriture eeprom 24LC16
merci a vous
The Following 2 Users Say Thank You to auto_tech For This Useful Post:
belle-palestine (16/12/2019), jah83 (16/12/2019)
Vieux 20/12/2019, 04h38   #3373
gabigafu
Avatar de gabigafu
la version 1.87 avec la virginisation de la DAE (direction assistée) de Mégane 4, Scénic 4, Talisman, Kadjar. Le codage se fait automatiquement à la première mise du contact.
The Following 15 Users Say Thank You to gabigafu For This Useful Post:
amine08 (20/12/2019), autodiagauto (28/11/2021), autoscan (04/01/2020), BILAUTO (20/12/2019), ggvaniou (20/12/2019), kevin22 (05/01/2020), multi290 (20/12/2019), NIZAR57 (22/12/2019), Pelican (20/12/2019), pouettedu76 (20/12/2019), progdebutant (20/12/2019), taxi5114 (20/12/2019), vibefm (20/12/2019), yahia1908 (20/12/2019), youcef_trik (04/01/2020)
Vieux 20/12/2019, 08h17   #3374
mahfoud lichani
Avatar de mahfoud lichani
Pouvoir de réputation: 36
espace 4 2.0 essence turbo
le client se présente pour entre autre: anomalie sur frein de parking, le voyant s'allume de temps à autre, et le frein reste enclenché au démarrage alors que théoriquement il doit "lâcher"
dtc avec clip 192, problème "contacteur de serrage redondant" 1.DEF
en consultant la page des paramètres: le vin est différent, et il est paramétré pour une boite auto, alors que le véhicule est équipé d'une boite manuelle 6 vitesses
CLIP ne donne pas la main pour changement du vin
renolink v 1.82 me donne cette possibilité
problème: le vin n'est pas passé, et après cette intervention, je me retrouve avec de nouveaux DTC, entre autres problème de communication sur le réseau multiplexé
qu est ce que j'ai loupé?
merci pour votre aide
bonne journée
---------- Post added at 08h17 ---------- Previous post was at 08h16 ----------
bonne journée
Vieux 20/12/2019, 12h32   #3375
thomas
Avatar de thomas
thomas is a name known to allthomas is a name known to allthomas is a name known to allthomas is a name known to allthomas is a name known to allthomas is a name known to all
as tu changé la config boite auto /manuel ?
si oui, alors remet comme c'etait.
The Following User Says Thank You to thomas For This Useful Post:
mahfoud lichani (21/12/2019)
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 21h06
fonctions digiprog3 TONY55 Tableau de bord en général 3 16/09/2014 15h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 18h57
quels sont toutes les fonctions de l'abritus72 mustauto Programmeur de clé 5 04/02/2013 11h50
Fuseau horaire GMT +1. Il est actuellement 08h16.
