30/10/2020, 17h46 | #1 |
Pouvoir de réputation: 0 |
Renault Can Clip v202 / Reprog v191
The Following 70 Users Say Thank You to yavheni For This Useful Post: | abdel93 (31/10/2020), aigle459 (01/11/2020), al1962 (19/12/2020), ALBALOCHI (18/09/2022), allpatchi (05/11/2020), anonymuserxx (15/12/2020), autodiagauto (30/10/2020), baccara25 (31/10/2020), baccaraboss (14/11/2020), bar94 (28/12/2020), bej 974 (16/04/2021), benazze38 (28/12/2020), boukrama (30/10/2020), brahim chafa3 (30/07/2021), Brahim6713 (01/02/2021), charlie29 (19/11/2023), clucky (05/11/2020), djkakoo (13/12/2020), drissdiag (01/11/2020), ebt255 (30/10/2020), Ecom (31/10/2020), ecutech (31/10/2020), estwood68 (16/04/2022), guyguy307 (01/11/2020), Honda (31/10/2020), hscar (01/02/2021), imcumen (07/11/2020), jardini (04/11/2020), kamel fouka (08/11/2020), kamilwlkp (14/07/2022), kitty-hawk (02/01/2021), krimo (19/12/2020), laurent78 (30/10/2020), lolo64 (04/11/2020), m.initial (12/04/2021), MAGHRIBI81 (09/12/2020), Malpa (03/11/2020), MAXYBOOM (30/11/2020), Monssif (01/09/2021), mvl (10/10/2022), nounour10 (12/11/2020), OILC93 (19/12/2020), Omar27 (09/02/2021), peugeot_307cc (31/10/2020), phi (31/10/2020), pompuy (05/02/2021), portugallands (18/12/2020), RAHMANIA AMMAR (10/07/2022), raimongil (17/12/2020), Rallyeman (30/10/2020), rapou30 (30/10/2020), Redoine (02/01/2021), reprogauto (10/02/2021), ricou8333 (31/10/2020), rocca32 (04/04/2021), samb4064 (31/10/2020), sami55 (31/10/2020), Silentmaxx (14/12/2020), taxi5114 (19/12/2020), Tidus97 (23/01/2021), Topal (30/01/2022), uncleseb (30/10/2020), vortex (31/10/2020), yahiadiag (14/02/2021), yanp55 (10/01/2021), youcef_trik (30/10/2020), yoyomartin2003 (05/12/2023), zoub (03/02/2021) |
30/10/2020, 17h53 | #2 |
Pouvoir de réputation: 19 |
bonjour merci pour ce partage reste a tester avec rtl2002 deja 201 fonctionne
The Following 6 Users Say Thank You to boukrama For This Useful Post: | autodiagauto (31/10/2020), baccaraboss (14/11/2020), guyguy307 (01/11/2020), mohhizbar (13/08/2021), yahiadiag (14/02/2021), zoub (03/02/2021) |
30/10/2020, 18h00 | #3 |
Pouvoir de réputation: 39 |
Bonsoir
Merci pour le partage ma connexion est très lente Un lien MEGA m'arrangerais mieux autodiagauto |
The Following User Says Thank You to autodiagauto For This Useful Post: | zoub (03/02/2021) |
30/10/2020, 19h22 | #4 |
The Following 11 Users Say Thank You to boukrama For This Useful Post: | autodiagauto (30/10/2020), baccaraboss (14/11/2020), bel27 (08/11/2020), Honda (30/10/2020), jéjé (01/11/2020), lolo64 (04/11/2020), LouisLeSinge (20/12/2020), mahfoud lichani (07/11/2020), rapou30 (08/11/2020), ricou8333 (31/10/2020), yahiadiag (14/02/2021) |
30/10/2020, 22h03 | #5 |
Pouvoir de réputation: 8 |
Bonsoir et merci également pour le partage, si possible d'avoir un liens Mega car moi aussi je possède une connexion déplorable.
merci par avance.
La connaissance s'acquiert par l'expérience, tout le reste n'est que de l'information. |
31/10/2020, 11h45 | #6 |
Pouvoir de réputation: 16 |
salut a tous
ya t il un lien mega car moi aussi j ai une connexion de merde merci pour le partage |
31/10/2020, 12h33 | #7 |
je vient de finir l’installation sur un clone reconnu je n’aie fait que la mise a jours 202 sur 200 toute les leds allumée pas encore tester sur voiture Merci a boukrama pour son aide A+ Sur T.E |
The Following User Says Thank You to autodiagauto For This Useful Post: | baccaraboss (01/11/2020) |
31/10/2020, 13h06 | #8 | |
---------- Post added at 14h06 ---------- Previous post was at 14h05 ---------- regarde dans votre boite |
The Following 5 Users Say Thank You to boukrama For This Useful Post: | autodiagauto (31/10/2020), baccaraboss (14/11/2020), Honda (31/10/2020), jéjé (01/11/2020), ricou8333 (31/10/2020) |
31/10/2020, 13h42 | #9 |
merci Boukrama pour ta réponse
bonne journée |
31/10/2020, 14h51 | #10 |
Pouvoir de réputation: 79 |
salut boukrama, je peux avoir le lien mega svp
merci |
31/10/2020, 15h07 | #11 |
The Following User Says Thank You to boukrama For This Useful Post: | baccaraboss (14/11/2020) |
11/11/2020, 21h04 | #12 |
Pouvoir de réputation: 22 |
Bonsoir des que je modifie les 2 fichier xml il mes votre installation de clip est corrompue
avant de me modifier sa s'ouvrer impec windows 10 x32 tout ok framework visual etc.. svp merci d'avance ---------- Post added at 22h04 ---------- Previous post was at 22h01 ---------- j'ai aussi une autre erreur xmsrenaultinstaller a cessé de fonctionner j'ai retelecharger canclip formater j'ai toujours ses de probleme
le partage est la force de l'homme |
14/12/2020, 23h20 | #13 |
Pouvoir de réputation: 6 |
Salut, la 202 est-elle "meilleure" que la 200 ? Il y a des modèles en plus ou une meilleure stabilité (d'après un autre commentaire, car je n'ai pas testé) ?
Merci ! |
18/12/2020, 22h48 | #14 |
Pouvoir de réputation: 33 |
Slt
Je vous fait un petit retour de mon essai de cette nouvelle version . Alors pour moi ça a fonctionné impec sur une clio 5 de 2020 . Temps de chargement pour l'accès a tous le réseau plutôt long mais une fois dedans c bon . J'ai pu lire les différents calculateurs supprimer les defauts présents sans probleme. Ce que j'ai pu constaté c'est que les voitures d'aujourd'hui sont de plus en plus complexe il y a carrément une procédure a respecter pour autoriser la lecture du diag . Coupure contact allumer contact et appui 2 fois sur accélérateur . Et après ça je vous raconte pas toute l'electronique présente dans le vehicule bref cette version est opérationnelle après faudra testé le reste donc faite des retours de vos expériences. |
The Following 2 Users Say Thank You to OILC93 For This Useful Post: | sami55 (19/12/2020), Silentmaxx (21/12/2020) |
19/12/2020, 05h33 | #15 |
Pouvoir de réputation: 27 |
Oui tu peut juste lire et affacer les default Pas de mode commande pas de réinitialisation. Du moin pour le moment, Et pour les multimarque c est pareil pour le moment ! Envoyé de mon PRA-LX1 en utilisant Tapatalk |
The Following 2 Users Say Thank You to Pelican For This Useful Post: | OILC93 (19/12/2020), Silentmaxx (21/12/2020) |
Renault Can Clip v200 / Reprog v189 | yavheni | Renault clip, DDT2000, Nissan consult | 16 | 30/10/2020 14h46 |
Clip v191 | zaouibachir | Renault clip, DDT2000, Nissan consult | 5 | 06/11/2019 15h38 |
Reprog calculo Renault Can clip ;-) | djello | Logiciel | 3 | 03/03/2016 08h50 |
renault clip reprog v83 | lihaven | Renault, Dacia, Nissan | 0 | 03/12/2009 07h39 |
renault can-clip reprog | vince | Renault, Dacia, Nissan | 0 | 24/02/2009 15h13 |
