Précédent   Tlemcen Car electronics > Tableau de bord, Habitacle & securité conducteur > Voyant et led
Voyant et led Questions et réponses pour résolutions des voyants allumés sur votre tableau de bord.
Vieux 01/05/2020, 23h00   #1
everson29
Avatar de everson29
Par défaut DF002 DAE Clio 3
Hello
qui peut me vérifier que le fichier est ok
j'ai fait erase df002 avec renault ecu tool mais le gars me dit même souci
à l'origine au diag il y avait bien DF002
j'ai lu eep en microchip 24LC16
ref 8200294982
Type de fichier : bin eep 24LC16 Ori.bin (2,0 Ko, 7 affichages)
Type de fichier : bin eep 24LC16 Ori_crcOK.bin (2,0 Ko, 4 affichages)
Vieux 01/05/2020, 23h05   #2
bkprog13
Avatar de bkprog13
Pouvoir de réputation: 81
salut l’ami, df002 c’est une panne matériel, faut remplacer la da.
The Following 8 Users Say Thank You to bkprog13 For This Useful Post:
akasa67 (02/05/2020), everson29 (02/05/2020), Formator (01/05/2020), ggvaniou (02/05/2020), INVICTUS (02/05/2020), jah83 (02/05/2020), louay (01/05/2020), Nour01100 (01/05/2020)
Vieux 01/05/2020, 23h48   #3
louay
Avatar de louay
louay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud oflouay has much to be proud of
salut df002 sur dae clio 3 et modus c'est un transistor qui lache
The Following 3 Users Say Thank You to louay For This Useful Post:
everson29 (02/05/2020), INVICTUS (02/05/2020), Nour01100 (01/05/2020)
Vieux 01/05/2020, 23h57   #4
bel27
Avatar de bel27
bel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond reputebel27 has a reputation beyond repute
salam il y a un tuto sur le forum pour cette panne
bel27 est connecté maintenant   Réponse avec citation
The Following User Says Thank You to bel27 For This Useful Post:
Vieux 02/05/2020, 04h35   #5
everson29
Avatar de everson29
Hello
Thanks
as tu la ref exacte de ce transistor
Vieux 02/05/2020, 04h46   #6
Pouvoir de réputation: 265
slt l ami moi je change la colonne part une Occasion apres sais la loterie mais voilà je ne touche pas le boitier de da a part ceux ou y a juste les relais à changer 107 etc et les Fiat le reste je change .. sais la sécurité..bon courage sa va le faire une colonne un vierge ecutool et basta..
Vieux 02/05/2020, 04h51   #7
zefirin
Avatar de zefirin
zefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to all
Bonjour ,
Si ca peut t'aider :
https://www.tlemcen-electronic.com/f...ighlight=MODUS
Bon week end à tous
zefirin est déconnecté   Réponse avec citation
The Following User Says Thank You to zefirin For This Useful Post:
Vieux 02/05/2020, 09h27   #8
louay
Avatar de louay
tu mets un condensateur en céramique ca fonctionne et c'est largement suffisant 22pf
https://www.hdevbot.fr/condensateurs...ue-50v-10.html
Vieux 02/05/2020, 10h23   #9
everson29
Avatar de everson29
merci mais ton lien ne donne rien
Vieux 02/05/2020, 11h19   #10
rapou30
Avatar de rapou30
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonjour, en cherchant sur le site je trouve ca :
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following User Says Thank You to rapou30 For This Useful Post:
Vieux 02/05/2020, 11h39   #11
nicokartcross
Avatar de nicokartcross
Pouvoir de réputation: 5
nicokartcross will become famous soon enoughnicokartcross will become famous soon enough
Par défaut Reprog
Bonjour a tous !!
Sur modus il existe une reprog de la DAE qui se fait avec un petit prog est qui peu la sauvé directement en eobd !!
J ai deja fait cette manip au boulot (renault)
Je vais rechercher le soft et l envoyé.
Si sa vous intéresse.
Le soft (fournit par Renault)vous dit tous de suite si c 'est matériel ou logiciel !!!
Cordialement
nicokartcross est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to nicokartcross For This Useful Post:
everson29 (02/05/2020), gary01 (02/05/2020), ggvaniou (02/05/2020), jean-marc 10 (02/05/2020), pouettedu76 (02/05/2020), zefirin (02/05/2020)
Vieux 02/05/2020, 11h53   #12
everson29
Avatar de everson29
Envoyé par nicokartcross Voir le message
Bonjour a tous !!
Cordialement
vraiment pas mal
Vieux 02/05/2020, 12h29   #13
lolo64
Avatar de lolo64
lolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to beholdlolo64 is a splendid one to behold
C'est bien le soft que tu veux dire:
https://www.tlemcen-electronic.com/f...6&postcount=20
Cdt.
lolo64 est déconnecté   Réponse avec citation
The Following User Says Thank You to lolo64 For This Useful Post:
Vieux 02/05/2020, 12h38   #14
lolo64
Avatar de lolo64
Comme ci-joint.
Type de fichier : jpg Tool.jpg (12,3 Ko, 62 affichages)
Vieux 02/05/2020, 13h31   #15
louay
Avatar de louay
Envoyé par everson29 Voir le message
oups un autre lien
https://www.ebay.fr/i/202827760165?c...YaAqhdEALw_wcB
nicokartcross (02/06/2020)
Suoorimer df002 dae modus 2005 mous.ben Immobilizer dumps/solutions 7 18/08/2016 12h04
suppression df002 dae modus foulques Immobilizer dumps/solutions 1 27/07/2016 23h23
DAE Modus DF002 perso69 Immobilizer dumps/solutions 15 21/03/2016 21h02
Dae clio3 df002 Auto16 Immobilizer dumps/solutions 0 16/04/2015 00h41
megane2 DF002 VERROU COLONNE electro_bordeaux1 Renault, Dacia, Nissan 4 01/06/2013 14h31
Fuseau horaire GMT +1. Il est actuellement 23h54.
