Vieux 20/01/2019, 14h09   #16
prinzo57
Avatar de prinzo57
Pouvoir de réputation: 41
Slt
Test l'alimentation de ton écu en premier après avoir regarde tout les fusibles ....
The Following User Says Thank You to prinzo57 For This Useful Post:
tarik_electronic (20/01/2019)
Vieux 20/01/2019, 15h41   #17
repcles
Avatar de repcles
repcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to allrepcles is a name known to all
slt , mets une masse direct ecu regarde si tu dialogue avec ecu.
---------- Post added at 16h41 ---------- Previous post was at 16h36 ----------
Envoyé par tarik_electronic Voir le message
voila le probleme
une 307 1,6 hdi de 2006 décide de ne plus démarrer Je tourne la clé, il ne se passe rien
demmarreur ok bsm ok
calculateur ed16C34 BSI JC LE MECANO QUE M'AMÈNE LE CALCULATEUR IL MA DIT PAS DE DIAG AVEL ECU
ET CE QUE POSSIBLE LE CALCUL ET HS ?
AU BIEN LE BSI HS?
MERCI
slt le mecano t es sur ta tt dit , je me mefie de certain? quand tu dis il ne se passe rien , a la demande demarrage le demarreur se lance tourne ?
a la mise du contact voyant moteur s allume?
repcles est déconnecté   Réponse avec citation
The Following User Says Thank You to repcles For This Useful Post:
Vieux 20/01/2019, 18h02   #18
tarik_electronic
Avatar de tarik_electronic
Pouvoir de réputation: 37
tarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond reputetarik_electronic has a reputation beyond repute
le demareur ne tourne pas .
avec un fil +12v dans bsm (demarreur direct tourne).
les alimmentation +12v GND et 12v ignition tt ok.
oublié pas le petit " thanks "
tarik_electronic est déconnecté   Réponse avec citation
Vieux 20/01/2019, 18h52   #19
yann3
Avatar de yann3
Pouvoir de réputation: 66
voila le probleme
AU BIEN LE BSI HS?
MERCI
verifie qu'il n'y a pas de defaut abs et que tu communique avec
Vieux 20/01/2019, 20h07   #20
saadaoui frere
Avatar de saadaoui frere
saadaoui frere has a spectacular aura aboutsaadaoui frere has a spectacular aura aboutsaadaoui frere has a spectacular aura about
dit a ton ami (bon mecano) controle le cablage et connecteur
---------- Post added at 21h07 ---------- Previous post was at 20h59 ----------
7m94 code pin
klm 225885
saadaoui frere est déconnecté   Réponse avec citation
The Following User Says Thank You to saadaoui frere For This Useful Post:
Vieux 20/01/2019, 20h18   #21
saadaoui frere
verifier cablage entre bsi et bsm et ecm voir desous garde bou cote gauche (le defaut dans cet cablage)
Vieux 20/01/2019, 20h34   #22
tarik_electronic
demain je reçois la voiture?
a mon avis bsi hs . jai 1 bsi meme referance 307 P2004 H05 je cherche le pinout sur table (FVDI) pr changer le pin et vin
---------- Post added at 09:34 PM ---------- Previous post was at 09:32 PM ----------
notre ami raed83300 a deja passer jc avec FVDI
https://www.tlemcen-electronic.com/f...ad.php?t=72471
Vieux 20/01/2019, 23h52   #23
prinzo57
Avatar de prinzo57
plus simple tu passe par bsichange tu lit l'original et tu injecte dans l'occasion sur table il te reste plus que faire la synchro de la commande clés si les bsi on les même références
Fuseau horaire GMT +1. Il est actuellement 01h27.
