17/07/2019, 11h51 | #1 |
Pouvoir de réputation: 14 |
Odis 5.1.6
La dernière version ODIS 5.1.6
LIEN : https://mega.nz/#F!ewIwHQoJ!6uViLA4gjn7hb9qdTHLTFQ MERCI + RÉPUTATION = MOT DE PASSE |
The Following 117 Users Say Thank You to Amine-VAG-COM For This Useful Post: | Abdelbassetkarim (15/01/2020), abdenore (08/11/2019), ABDOU2375 (09/12/2020), abghad (16/01/2020), aigle459 (30/10/2019), alain139 (30/10/2020), Alcaps76 (20/07/2019), Alessiapia14 (19/09/2019), algerkov (15/02/2020), Arnaud_06 (03/01/2020), AUTOKIMO (07/04/2020), azicar (23/03/2020), bassh (20/03/2020), BenjiAudi (30/11/2019), Bernard34 (20/04/2020), BilChip (05/07/2020), bino78 (16/12/2019), blaude205 (22/12/2019), bmfrep (25/11/2021), Bob.dh (22/11/2019), boss2041 (27/04/2020), boukrama (17/07/2019), bouzimeca (26/12/2019), bugess (05/06/2020), calixo22 (15/12/2019), chave56 (29/10/2019), Chris911 (25/07/2020), cyber (29/12/2020), daimler (28/03/2020), damientechnic (26/03/2020), dart (20/03/2020), dcdes (06/08/2020), dede49150 (20/08/2020), deltamike (03/01/2020), Diode Zener (04/06/2021), Dix (15/04/2020), el3azouni (03/06/2023), elamin (16/09/2021), elmostro (15/12/2019), excudo (07/09/2019), fakhrouch (15/12/2019), fayssal.vision (31/10/2019), Fougerit (08/12/2019), freeman2010 (05/12/2019), Freestyle31 (16/09/2021), Geof7 (05/08/2022), gringo783 (18/11/2019), hamma bosch (06/02/2020), hams (24/01/2020), imapx2 (05/11/2019), jaed63 (12/07/2021), jn-trucks (01/05/2020), joe_isma (24/12/2019), jroz (03/01/2020), juljul (30/08/2020), KAISERAJT (12/08/2020), keydann (07/01/2020), khalil84 (28/02/2023), kimo2016 (10/10/2020), koolrawoul (13/06/2020), lahmer07 (15/04/2020), Lalimule (23/01/2020), Larson92 (24/08/2019), LittleBoy (17/05/2020), lokher (20/02/2020), louay (27/08/2019), Loutuning (05/02/2020), Lowik Waptor (29/06/2020), magrig (06/03/2020), mahdi06 (28/03/2020), mars2008 (22/10/2021), mecano41 (18/06/2020), Med1387 (16/12/2019), Meuchine (22/11/2021), Micka1115 (27/01/2020), mickss (23/01/2020), NAJIBBB (28/12/2020), nasisamy (15/12/2019), neoamtrixe (22/01/2020), neocool (19/09/2021), nounour10 (18/03/2020), patricio (13/07/2020), portugallands (26/01/2020), pouma (02/01/2020), poze (16/08/2021), progdebutant (07/08/2019), RBX59100 (01/09/2021), redboyskh (08/08/2019), saadaoui frere (25/02/2020), salah72 (27/10/2019), salaheddinel (27/05/2021), samy.one (06/08/2022), satel0000 (09/01/2020), sl60 (23/08/2020), slklite (18/05/2020), spider man2 (19/05/2020), Steve7698 (03/07/2020), Superyago (26/01/2020), taxi5114 (08/03/2020), Truc (08/08/2019), uncleseb (30/12/2019), VALISE-DIAG30 (31/01/2021), vas-man06 (10/01/2020), vince11 (18/10/2020), vortex (23/08/2019), winxp (04/09/2021), wolko (17/03/2020), xav2a (01/03/2020), xavi5757 (27/12/2019), yaser5s (29/08/2019), youcef_trik (23/06/2020), ysc198747 (01/03/2020), zaouibachir (05/11/2019), zatazk (20/07/2019), zouaoui mohamed (17/07/2019) |
17/07/2019, 19h24 | #2 |
Pouvoir de réputation: 19 |
merci amine pour le partage la version 5.1.6 ya une activation avec
The Following User Says Thank You to boukrama For This Useful Post: | vince11 (18/10/2020) |
30/11/2019, 16h26 | #4 |
Pouvoir de réputation: 9 |
Merci à toi pour ton partage, cependant j' ai un problème à la première étape de l' installation, en exécutant l' exe en admin.
C++ 2005 bien désinstallé Déjà installé plusieurs fois 4.3.2 et 4.3.3 Idem sur trois pc.. Si quelqu'un à une idée ce serait très sympa merci
KESSV2&KTAG ORI MASTER AVDI VN/VK FULL ORI AUTOTUNER MASTER VCDS MMPS FGTECH54 VAS VCP+K OLS501 |
The Following User Says Thank You to BenjiAudi For This Useful Post: | Trident (03/01/2020) |
30/11/2019, 17h56 | #5 |
An error with one of the software components was detected. The ODIS Service installation will be removed again. Uninstalling the vehicle connection (VW MCD, PDU, API) will be attempted first. This may take several minutes. Please contact Support.
15/12/2019, 09h45 | #6 |
Pouvoir de réputation: 31 |
vous êtes bien en WINDOWS 7 32 bit et non 64 bit pour ceux qui ont des soucis? J'avais ce message quand je tentais l'install sur 64 bit ...
The Following User Says Thank You to elmostro For This Useful Post: | baccaraboss (16/06/2020) |
15/12/2019, 13h55 | #7 |
Pouvoir de réputation: 17 |
Erreur installation
J'avais déjà installé ODIS 5.1.6 sur mon pc et ca a bien fonctionné. Entre temps, j'ai formaté et installé Xentry PASSTHRU avec les drivers pour la VAS5054. Et en voulant réinstaller ODIS, j'obtiens ce message d'erreur et l'installation s'arrete: com.install4j.api.beans.UndefinedVariableException : installerdx Je ne sais pas si c'est à cause de l'installation de xentry passthru qui créer un conflit etc Ci joint les capture d'erreur et le fichier log (indiquant "source inconnue) Merci pour votre aide |
The Following 2 Users Say Thank You to ToNy68 For This Useful Post: | Amine-VAG-COM (16/12/2019), Trident (03/01/2020) |
16/12/2019, 09h14 | #8 |
IL faut formater nouveau
1 - install odis5.1.6 2 - install xentry passthru |
The Following User Says Thank You to Amine-VAG-COM For This Useful Post: | ToNy68 (16/12/2019) |
16/12/2019, 16h21 | #9 |
D'accord, merci.
C'est vrai que l'ordre d'installation peut être important |
The Following User Says Thank You to ToNy68 For This Useful Post: | neoamtrixe (22/01/2020) |
30/12/2019, 07h07 | #10 |
Pouvoir de réputation: 50 |
Salut, n'aurais-tu pas Xentry installer sur ton PC.
03/01/2020, 01h45 | #11 | |
Pouvoir de réputation: 10 |
Quand tu as ce message, redémarre ton ordinateur et ne tient pas compte de ce qui est écrit car ODIS est correctement installé néanmoins. J'ai eu le même problème et rien à faire même sur Windows fraîchement installé, la même erreur. |
02/04/2020, 01h16 | #12 | |
Re
pour résoudre le problème il Faut : 1) désintaller C++ 2005 2)Supprimer tous les fichier installer lors de l'essaie d'installation => Dans C 3) Redémarre le Pc 4) Relancer l'installation Normalement le logiciel va installer automatiquement C++ 2005. Citation:
13/04/2020, 01h05 | #13 |
Pouvoir de réputation: 37 |
Salut, sélectionne directement le dossier dans lequel se trouve ODIS.
S’il est sur dans ton dossier «*téléchargement*» tu sélectionne «*telechargement*» et tu fais ok. ---------- Post added at 00h05 ---------- Previous post was at 23h58 ---------- Et après l’installation réussie tu peux continuer à venir aider sur le forum... |
The Following 2 Users Say Thank You to Mook31 For This Useful Post: | baccaraboss (16/06/2020), Pilouf (13/04/2020) |
14/04/2020, 13h46 | #14 |
Pas de retour, pas de thanks, franchement c’est lourd...
The Following User Says Thank You to Mook31 For This Useful Post: | baccaraboss (16/06/2020) |
14/04/2020, 13h58 | #15 |
Pouvoir de réputation: 74 |
The Following 3 Users Say Thank You to Pilouf For This Useful Post: |
Outils de la discussion | |
Odis 3.1.0 | Alex0221 | VAS5054, VCDS, ODIS | 0 | 11/12/2016 19h50 |
