Section for english users English talking about cars, problems and solutions ... |
14/04/2016, 13h51 | #1 |
Pouvoir de réputation: 0 |
clone DDCR
Hello everyone. I have a question about ecu compatibility between a ecu ddcr mounted in a renault megane 2 1.5 dci euro3 and a ecu ddcr mounted in a renault clio 1.5 dci euro3. It's possible to be replaced, after rewrite the software? I have original ECU from megane II with this serial nr.:8200334419 , 8200340926 , DDCR R0410B024A , SERIAL No80975965 JWG and the ecu from clio have this serials : 8200334540 , 8200412768, DDCR R041B026C , SERIAL No 82436926 JXG
Thank you. |
14/04/2016, 15h25 | #2 |
Pouvoir de réputation: 22 |
salu ecu clio ddcr et megane ddcr ne sont pas compatible .ecu ddcr megane eeprom atmel 95080 et l autre clio 95080
20/04/2016, 19h48 | #3 |
k .merci beaucoup.
another question : i found another ecu with same HW serial like original.it's possible to clone the ecu only on obd connector, or must cut the plastic case for desoldering and read eeprom to clone IMMO? i have fgtech galleto v45 china clone, mpps v16 and fg galletto 1260. the new ecu have same proprieties like old ecu, same power 82hp, but i make a chiptunning on mine ecu. |
21/04/2016, 13h56 | #4 |
non il faut dessouder eeprpm et la ressouder
21/04/2016, 21h07 | #5 |
thank you...best regards
09/05/2016, 21h03 | #6 |
Guest
Messages: n/a
06/06/2016, 08h00 | #7 |
hello guys. i come back with another question and request to help: can anyone to tell me how virginize this ecu? i read some forum , and i see this tips:
Can be done ONLY virgin Delphy DDCR ecu. On the 95080 flash, : > Put line 0000 : all 16 bytes to FF AND line 0001 : first 9 bytes to FF, and this is virgin. Use emu or recode ecu by original uch and keys as you wish 100 % guaranteed solution, virginised those ecus many, many times ! so....any advise?! |
06/06/2016, 15h44 | #8 |
Pouvoir de réputation: 13 |
post the original dump i will do it
best regards |
22/06/2017, 19h04 | #9 |
it is right, only virgin. but you can use immo emulator like julie or similar if you need immo off after virginizing
22/06/2017, 19h27 | #10 |
Pouvoir de réputation: 265 |
Slt si c'est le même tu fais un vierge tu remet vin code injecteurs..
The Following User Says Thank You to akasa67 For This Useful Post: | sharediag (04/01/2019) |
04/01/2019, 22h49 | #11 |
Pouvoir de réputation: 8 |
bonsoir,
apres plusieurs dessoudage je viens de bousiller la st95080 de DDCR megane 2 1.5 dci de 2003 REF: 8200334419 , 8200340926 , R0410B024A si qlq1 peut me filer le dump orig merci d avance. |
04/01/2019, 22h52 | #12 |
ou si qlq1 peut me confirmer si ce dump n est pas corrompu.
06/01/2019, 14h34 | #13 |
ou un dump fonctionnel pour le calculateur en référence.
merci pour votre aide. |
10/01/2019, 18h43 | #14 |
Bonsoir.Comme déjà dit il suffit de virginiser l'eprom (off partout)et ça doit démarrer.Il ne reste plus qu'à remettre le vin et les codes injecteurs pour ne pas avoir de remontée de défauts.
10/01/2019, 23h07 | #15 |
Pouvoir de réputation: 16 |
Ton eeprom soit tu mets tout en fffffffffff eeprom totalement vierge et tu le ressoudes dans ce cas la voiture demarre voyant prechauffage alumé regime moteur 1100rpm et pas d'acceleration tu dois rentrer les code injecteurs.
Deusieme cas virginiser seulement les deux premieres lignes en fffffff tu ressoudes eeprom demarrage directe sans prechauffage Voila c à vous de choisir ce que tu veux faire |
Ddcr 1,5 dci | costinet | Renault, Dacia, Nissan | 7 | 02/10/2019 18h33 |
DDCR 1.5 renault can | Ecomouv | Immobilizer dumps/solutions | 3 | 19/01/2015 12h59 |
bdm delphi ddcr | zaouibachir | Flasheur de calculateur | 3 | 16/06/2013 01h27 |
