slave
Vieux 17/07/2019, 11h51   #1
Amine-VAG-COM
Avatar de Amine-VAG-COM
Amine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to beholdAmine-VAG-COM is a splendid one to behold
Par défaut Odis 5.1.6
La dernière version ODIS 5.1.6
LIEN : https://mega.nz/#F!ewIwHQoJ!6uViLA4gjn7hb9qdTHLTFQ
MERCI + RÉPUTATION = MOT DE PASSE
Amine-VAG-COM est déconnecté   Réponse avec citation
The Following 117 Users Say Thank You to Amine-VAG-COM For This Useful Post:
Abdelbassetkarim (15/01/2020), abdenore (08/11/2019), ABDOU2375 (09/12/2020), abghad (16/01/2020), aigle459 (30/10/2019), alain139 (30/10/2020), Alcaps76 (20/07/2019), Alessiapia14 (19/09/2019), algerkov (15/02/2020), Arnaud_06 (03/01/2020), AUTOKIMO (07/04/2020), azicar (23/03/2020), bassh (20/03/2020), BenjiAudi (30/11/2019), Bernard34 (20/04/2020), BilChip (05/07/2020), bino78 (16/12/2019), blaude205 (22/12/2019), bmfrep (25/11/2021), Bob.dh (22/11/2019), boss2041 (27/04/2020), boukrama (17/07/2019), bouzimeca (26/12/2019), bugess (05/06/2020), calixo22 (15/12/2019), chave56 (29/10/2019), Chris911 (25/07/2020), cyber (29/12/2020), daimler (28/03/2020), damientechnic (26/03/2020), dart (20/03/2020), dcdes (06/08/2020), dede49150 (20/08/2020), deltamike (03/01/2020), Diode Zener (04/06/2021), Dix (15/04/2020), el3azouni (03/06/2023), elamin (16/09/2021), elmostro (15/12/2019), excudo (07/09/2019), fakhrouch (15/12/2019), fayssal.vision (31/10/2019), Fougerit (08/12/2019), freeman2010 (05/12/2019), Freestyle31 (16/09/2021), Geof7 (05/08/2022), gringo783 (18/11/2019), hamma bosch (06/02/2020), hams (24/01/2020), imapx2 (05/11/2019), jaed63 (12/07/2021), jn-trucks (01/05/2020), joe_isma (24/12/2019), jroz (03/01/2020), juljul (30/08/2020), KAISERAJT (12/08/2020), keydann (07/01/2020), khalil84 (28/02/2023), kimo2016 (10/10/2020), koolrawoul (13/06/2020), lahmer07 (15/04/2020), Lalimule (23/01/2020), Larson92 (24/08/2019), LittleBoy (17/05/2020), lokher (20/02/2020), louay (27/08/2019), Loutuning (05/02/2020), Lowik Waptor (29/06/2020), magrig (06/03/2020), mahdi06 (28/03/2020), mars2008 (22/10/2021), mecano41 (18/06/2020), Med1387 (16/12/2019), Meuchine (22/11/2021), Micka1115 (27/01/2020), mickss (23/01/2020), NAJIBBB (28/12/2020), nasisamy (15/12/2019), neoamtrixe (22/01/2020), neocool (19/09/2021), nounour10 (18/03/2020), patricio (13/07/2020), portugallands (26/01/2020), pouma (02/01/2020), poze (16/08/2021), progdebutant (07/08/2019), RBX59100 (01/09/2021), redboyskh (08/08/2019), saadaoui frere (25/02/2020), salah72 (27/10/2019), salaheddinel (27/05/2021), samy.one (06/08/2022), satel0000 (09/01/2020), sl60 (23/08/2020), slklite (18/05/2020), spider man2 (19/05/2020), Steve7698 (03/07/2020), Superyago (26/01/2020), taxi5114 (08/03/2020), Truc (08/08/2019), uncleseb (30/12/2019), VALISE-DIAG30 (31/01/2021), vas-man06 (10/01/2020), vince11 (18/10/2020), vortex (23/08/2019), winxp (04/09/2021), wolko (17/03/2020), xav2a (01/03/2020), xavi5757 (27/12/2019), yaser5s (29/08/2019), youcef_trik (23/06/2020), ysc198747 (01/03/2020), zaouibachir (05/11/2019), zatazk (20/07/2019), zouaoui mohamed (17/07/2019)
Vieux 17/07/2019, 19h24   #2
boukrama
Avatar de boukrama
boukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud of
merci amine pour le partage la version 5.1.6 ya une activation avec
boukrama est déconnecté   Réponse avec citation
The Following User Says Thank You to boukrama For This Useful Post:
Vieux 27/08/2019, 11h03   #3
Amine-VAG-COM
Envoyé par boukrama Voir le message
non ya pas d'activation
The Following User Says Thank You to Amine-VAG-COM For This Useful Post:
Vieux 30/11/2019, 16h26   #4
BenjiAudi
Avatar de BenjiAudi
Pouvoir de réputation: 9
BenjiAudi is a jewel in the roughBenjiAudi is a jewel in the roughBenjiAudi is a jewel in the roughBenjiAudi is a jewel in the rough
Merci à toi pour ton partage, cependant j' ai un problème à la première étape de l' installation, en exécutant l' exe en admin.
C++ 2005 bien désinstallé
Déjà installé plusieurs fois 4.3.2 et 4.3.3
Idem sur trois pc..
Si quelqu'un à une idée ce serait très sympa merci
Type de fichier : jpg 78105065_2474633212775409_35798333368827904_n (1).jpg (108,2 Ko, 163 affichages)
KESSV2&KTAG ORI MASTER AVDI VN/VK FULL ORI AUTOTUNER MASTER VCDS MMPS FGTECH54 VAS VCP+K OLS501
BenjiAudi est déconnecté   Réponse avec citation
The Following User Says Thank You to BenjiAudi For This Useful Post:
Trident (03/01/2020)
Vieux 30/11/2019, 17h56   #5
BenjiAudi
Avatar de BenjiAudi
An error with one of the software components was detected. The ODIS Service installation will be removed again. Uninstalling the vehicle connection (VW MCD, PDU, API) will be attempted first. This may take several minutes. Please contact Support.
Vieux 15/12/2019, 09h45   #6
elmostro
Avatar de elmostro
Pouvoir de réputation: 31
vous êtes bien en WINDOWS 7 32 bit et non 64 bit pour ceux qui ont des soucis? J'avais ce message quand je tentais l'install sur 64 bit ...
elmostro est connecté maintenant   Réponse avec citation
baccaraboss (16/06/2020)
Vieux 15/12/2019, 13h55   #7
ToNy68
Avatar de ToNy68
ToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to beholdToNy68 is a splendid one to behold
Par défaut Erreur installation
J'avais déjà installé ODIS 5.1.6 sur mon pc et ca a bien fonctionné.
Entre temps, j'ai formaté et installé Xentry PASSTHRU avec les drivers pour la VAS5054.
Et en voulant réinstaller ODIS, j'obtiens ce message d'erreur et l'installation s'arrete:
com.install4j.api.beans.UndefinedVariableException : installerdx
Je ne sais pas si c'est à cause de l'installation de xentry passthru qui créer un conflit etc
Ci joint les capture d'erreur et le fichier log (indiquant "source inconnue)
Merci pour votre aide
Type de fichier : jpg erreur odis1.JPG (33,7 Ko, 78 affichages)
Type de fichier : jpg erreur odis2.JPG (24,0 Ko, 54 affichages)
Type de fichier : txt install4jError8949819162255578084.txt (2,8 Ko, 24 affichages)
ToNy68 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to ToNy68 For This Useful Post:
Amine-VAG-COM (16/12/2019), Trident (03/01/2020)
Vieux 16/12/2019, 09h14   #8
Amine-VAG-COM
IL faut formater nouveau
1 - install odis5.1.6
2 - install xentry passthru
ToNy68 (16/12/2019)
Vieux 16/12/2019, 16h21   #9
ToNy68
Avatar de ToNy68
D'accord, merci.
C'est vrai que l'ordre d'installation peut être important
The Following User Says Thank You to ToNy68 For This Useful Post:
Vieux 30/12/2019, 07h07   #10
zingilingiling
Avatar de zingilingiling
Envoyé par BenjiAudi Voir le message
Idem sur trois pc..
Salut, n'aurais-tu pas Xentry installer sur ton PC.
Vieux 03/01/2020, 01h45   #11
Trident
Avatar de Trident
Trident is a jewel in the roughTrident is a jewel in the roughTrident is a jewel in the roughTrident is a jewel in the rough
Envoyé par ToNy68 Voir le message
Quand tu as ce message, redémarre ton ordinateur et ne tient pas compte de ce qui est écrit car ODIS est correctement installé néanmoins.
J'ai eu le même problème et rien à faire même sur Windows fraîchement installé, la même erreur.
Trident est déconnecté   Réponse avec citation
Vieux 02/04/2020, 01h16   #12
Wayne
Avatar de Wayne
Wayne has a spectacular aura aboutWayne has a spectacular aura aboutWayne has a spectacular aura about
Par défaut Re
pour résoudre le problème il Faut :
1) désintaller C++ 2005
2)Supprimer tous les fichier installer lors de l'essaie d'installation => Dans C
3) Redémarre le Pc
4) Relancer l'installation
Normalement le logiciel va installer automatiquement C++ 2005.
Wayne est déconnecté   Réponse avec citation
Vieux 13/04/2020, 01h05   #13
Mook31
Avatar de Mook31
Salut, sélectionne directement le dossier dans lequel se trouve ODIS.
S’il est sur dans ton dossier «*téléchargement*» tu sélectionne «*telechargement*» et tu fais ok.
---------- Post added at 00h05 ---------- Previous post was at 23h58 ----------
Et après l’installation réussie tu peux continuer à venir aider sur le forum...
The Following 2 Users Say Thank You to Mook31 For This Useful Post:
baccaraboss (16/06/2020), Pilouf (13/04/2020)
Vieux 14/04/2020, 13h46   #14
Mook31
Avatar de Mook31
Pas de retour, pas de thanks, franchement c’est lourd...
The Following User Says Thank You to Mook31 For This Useful Post:
Vieux 14/04/2020, 13h58   #15
Pilouf
Avatar de Pilouf
Pouvoir de réputation: 74
Unhappy
Envoyé par Mook31 Voir le message
Salut Mook,
Je pense pas qu'il soit là pour aider où faire des retours d'infos !!
Quand tu vois les messages qu'il a posté...
The Following 3 Users Say Thank You to Pilouf For This Useful Post:
baccaraboss (18/06/2020), gringo783 (14/04/2020), Mook31 (14/04/2020)
Odis 3.1.0 Alex0221 VAS5054, VCDS, ODIS 0 11/12/2016 19h50
Fuseau horaire GMT +1. Il est actuellement 20h59.
