Vieux 20/02/2021, 17h28   #31
Med1387
Avatar de Med1387
Med1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant futureMed1387 has a brilliant future
Envoyé par zingilingiling Voir le message
serait il possible d'avoir l'activation ?
---------- Post added at 17h37 ---------- Previous post was at 17h36 ----------
324e66-08dea6-f9b5ef-7495ee
Salut si tu veux je t’envoie le keygen
zingilingiling
DQVJG4A2W4KVH5XB4U8JEHSBW3V7B5U4K86GGGU28S4RMLC233 7TKURT4D5VEUTJWD3SC
Med1387 est déconnecté   Réponse avec citation
The Following User Says Thank You to Med1387 For This Useful Post:
zingilingiling (20/02/2021)
Vieux 20/02/2021, 18h49   #32
zingilingiling
Avatar de zingilingiling
Envoyé par Med1387 Voir le message
zingilingiling
Merci Med1387,
J'ai une erreur :
Error Reading the licence file:NotAfter:Fri Dec 0408:57:39 CET 2020
This licence is invalid.
Vieux 20/02/2021, 19h07   #33
Med1387
Avatar de Med1387
Merci Med1387,
J'ai une erreur :
Je te l'envoie en mp
Vieux 21/02/2021, 18h03   #34
SaTouF
Avatar de SaTouF
Pouvoir de réputation: 35
SaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond reputeSaTouF has a reputation beyond repute
le problème c'est peut-être parce que tu as un espace --> C233"ICI"7TKUR
au cas ou tu ai pas le keygen:
C89S4S72E7U6XNJ76HY7EG9P2YVMCZN8PX49Y832PQM3DLNF4W 85X9TCGA6W5WV6YVR6SQHRCR5GLHJ
SaTouF est déconnecté   Réponse avec citation
The Following User Says Thank You to SaTouF For This Useful Post:
zingilingiling (21/02/2021)
Vieux 21/02/2021, 21h51   #35
zingilingiling
Envoyé par SaTouF Voir le message
salut SaTouF,
J n'ai pas compris quand tu dis cela =>C233"ICI"7TKUR
J'ai refait un PC avec Windows 7 64bit a neuf et j'ai toujours le même erreur.
Je vais peux etre faire comme toi , envoyer le PC par les air ?
Est il possible de supprimer l'activation sans supprimer l'installation ?
Vieux 21/02/2021, 22h25   #36
zingilingiling
Salut je viens de comprendre quand tu parle de cela =>>C233"ICI"7TKUR
Non il n'y a pas espace.
L'enregistrement ce fait bien.
Mais lorsque que je lance le soft j'ai le défaut indiqué au dessus.
Vieux 21/02/2021, 23h25   #37
SaTouF
Avatar de SaTouF
Il faut que tu change la date du PC
Pas après le 04/12/2020
Essaie pour voir
Vieux 21/02/2021, 23h33   #38
zingilingiling
Essaie pour voir
C'est ce que j'ai fait au niveau de la barre des tâches, mais cela n'a pas fonctionné.
Par contre je ne l'ai pas fait depuis le bios .
J'essaie demain. 😤
Vieux 22/02/2021, 05h25   #39
zingilingiling
Je viens de changer blandate dans le Bios.
Le problème reste le même.
Vieux 22/02/2021, 07h54   #40
maximin
Avatar de maximin
maximin is a glorious beacon of lightmaximin is a glorious beacon of lightmaximin is a glorious beacon of lightmaximin is a glorious beacon of lightmaximin is a glorious beacon of lightmaximin is a glorious beacon of light
Salut ,
Retire la pile sur la carte mère et remet là
refait le changement date !?
maximin est déconnecté   Réponse avec citation
Vieux 22/02/2021, 09h10   #41
zingilingiling
Envoyé par maximin Voir le message
Salut ,
J'ai cru comprendre que la licey qui était mis à disposition allait jusqu'à 2030?
Vieux 22/02/2021, 17h37   #42
zingilingiling
Salut le peuple.
J'ai enfin réussi à installer le soft 🤬😡🤬😡🎉🎉
Vous aviez raison il faut changer la date comme vous l'avez annoncé 😁.
Mais il faut mettre seulement quelques mois avant la date annoncée (3 MOIS) par l'erreur indiqué plus haut (Déc 2019).
Merci a vous.
The Following User Says Thank You to zingilingiling For This Useful Post:
Med1387 (22/02/2021)
Vieux 22/02/2021, 19h37   #43
SaTouF
Avatar de SaTouF
c'était obligé ça m'est arrivé mdr
la tablette s'en souvient encore
Vieux 22/02/2021, 20h04   #44
zingilingiling
lol,
J'ai l'impression que je suis le seul à avoir eu le problème de date au niveau de ma licence.
Donc une question pourrait se poser, vu que j'ai modifié la date sur mon PC (2019), le mode online peut il fonctionner ?
Vieux 22/02/2021, 20h05   #45
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 59
Par défaut ODIS-Engineering_12_1_0
Salut zing,
Ya peut être une solution,
zingilingiling (22/02/2021)
Driver vas5054a win 10 odis e et odis s Alessiapia14 VAS5054, VCDS, ODIS 4 29/05/2020 19h20
diference entre ODIS SEVICE et ODIS ENGINERING fractal007 VAS5054, VCDS, ODIS 6 24/09/2019 15h36
vas odis 4.0.0 karera 1 VAS5054, VCDS, ODIS 6 05/10/2017 16h29
Fuseau horaire GMT +1. Il est actuellement 05h52.
