Précédent   Tlemcen Car electronics > Tableau de bord, Habitacle & securité conducteur > Compteur kilométrique
Compteur kilométrique Idée, méthode et astuces pour les corrections de compteur de kilométrage et aussi les procédures et schématique de démontage. (Attention: Cette section n'est pas destinée aux trafiquants de kilométrage)
Vieux 28/12/2018, 13h15   #31
car83
Avatar de car83
car83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud ofcar83 has much to be proud of
Avec la version 5.0... en lisant l’EPROM est en modifiant le code pin. Ça fait un bail donc la procédure exacte j’ai oublié. C'est la seule fois que j'ai utilisé ce câble.
car83 est déconnecté   Réponse avec citation
Vieux 29/12/2018, 11h50   #32
wscar
Avatar de wscar
wscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to behold
Determining IMMO-ID & VIN (ECU)
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
[Done, Go Back]
[Close Controller, Go Back - 06]
Determining IMMO-ID & VIN (Instrument Cluster)
[Select]
[25 - Immobilizer]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
[Done, Go Back]
Instrument Cluster Swapping (Used Cluster)
Prerequisites:
The NEW (USED) cluster is installed in the car.
Battery voltage at least 12.0 V.
All relevant coding and adaptation values have been transferred from the OLD (ORIGINAL) cluster to the NEW (USED) cluster.
Make sure to have BOTH PIN's, from the OLD (ORIGINAL) and the NEW (USED) instrument cluster.
Make sure to have the Radio Code (for factory radios only).
[Select]
[25 - Immobilizer]
[Security Access - 16]
For the following procedure, use the PIN of the NEW (USED) instrument cluster.
4-digit PIN
Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
[Do it!]
The instrument cluster now shows Immobilizer Adaptation active, wait until it changes to Immobilizer active - this may take up to 2 Minutes.
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
For the following procedure, use the PIN of the OLD (ORIGINAL) instrument cluster.
4-digit PIN
[Test]
[Save]
[Done, Go Back]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Verify that the NEW (USED) instrument cluster now shows the VIN/IMMO-ID of the vehicle now.
Voila la procedure au vcds extrait de leur site suit la a la lettre et sa fonctionneras.
---------- Post added at 12h50 ---------- Previous post was at 12h46 ----------
Ensuite il te resteras a faire apprentissage fes cleeset ca seras good!
Si j ai peu aider n oubliez pas de cliquer sur THANKS!
wscar est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to wscar For This Useful Post:
alinjadii (29/12/2018), car83 (29/12/2018), DIAGSYSTEM25 (29/12/2018), khoums (29/12/2018), pouettedu76 (08/01/2020)
Vieux 04/01/2020, 22h47   #33
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Avec quoi extraire le fichier sur table?
Vieux 05/01/2020, 22h25   #34
Tristan25
Avatar de Tristan25
Que veut tu faire exactement? Le post date
Vieux 05/01/2020, 22h27   #35
DIAGSYSTEM25
Extraire le fichier complet car la dessus il est une parti sur l epprom et la seconde parti qui ce trouve sur les 2 processeurs fijitsu
The Following User Says Thank You to DIAGSYSTEM25 For This Useful Post:
calixo22 (05/01/2020)
Vieux 05/01/2020, 22h42   #36
Tristan25
Avatar de Tristan25
Oui c’est sa il te faudra de quoi alimenter ton compteur sur table et apres ton depend tu a quoi comme materiel? Tu est pas loin de chez moi si tu a besoin
Vieux 06/01/2020, 04h42   #37
Tristan25
Avatar de Tristan25
Oui c’est sur mais tous depend pourquoi il le change
Vieux 06/01/2020, 07h18   #38
DIAGSYSTEM25
En faites j ai déjà fait toutes les manipulations possibles et même swaps epprom. Sa ne va pas
Quand je swaps il m indique 0 km et safe
Vieux 06/01/2020, 07h33   #39
Tristan25
Avatar de Tristan25
Oui c’est normal c’est crypter tu a quoi comme materiel?
Vieux 06/01/2020, 20h55   #40
Tristan25
Avatar de Tristan25
Tu en est ou?
Vieux 07/01/2020, 19h49   #41
DIAGSYSTEM25
J'ai carprog,avdi,xprog, mais pour le lire il faudrait qu il s allume quand on branche l alimentation.
Je pense que je vais essayer j'ai dit essayer de saper les Fujitsu.....je croise les doigts car c'est délicat comme travail
Vieux 07/01/2020, 21h22   #42
Tristan25
Avatar de Tristan25
Fabrique toi un banc sur table tu risque de tous casser si ta jamais souder sa tu va dire quoi au clien si tu casse tous lol vien a la maison avec tes 2 compteur on fait sa en 10 min le temps d’un cafe[emoji6]
The Following 2 Users Say Thank You to Tristan25 For This Useful Post:
DIAGSYSTEM25 (08/01/2020), pouettedu76 (08/01/2020)
Vieux 08/01/2020, 07h38   #43
DIAGSYSTEM25
Tu es d ou?
Tu veux le faire avec quoi?
Vieux 08/01/2020, 08h03   #44
Tristan25
Avatar de Tristan25
Le russey 25210
Je peux avec carprog ori et fvdi
Vieux 08/01/2020, 10h12   #45
DIAGSYSTEM25
Ah ok j ai aussi en origine le carprog et j'ai également avdi mais pour que sz fonctionne il faut que il soit en état de marche (alimenté).moi je veux lire le dump depuis un programmateur
Clonage Compteur AUDI Adrien13 Compteur kilométrique 13 07/12/2018 04h56
Compteur audi a4 2.5 tdi 2004 DIAGSYSTEM25 Compteur kilométrique 2 28/11/2018 17h12
Remplacement et clonage compteur audi A2 YomGui Réparation & Programmation des calculateurs 4 05/08/2016 11h30
Compteur Audi A3 de 2004 fm09 Compteur kilométrique 1 06/05/2015 20h07
Clonage compteur audi TT Kevauto Compteur kilométrique 3 13/11/2012 18h04
Fuseau horaire GMT +1. Il est actuellement 05h37.
