Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > FoCOM, Examiner Smart
Vieux 18/02/2019, 20h26   #1
mcb58
Avatar de mcb58
mcb58 is on a distinguished road
Par défaut Ficom version 0.2.12419, Feb 18 2019
Hello dear friends
here is the lastest version Ficom
https://mega.nz/#!5iZzGQTS!QZdh9oRxq...06qlmPDb7QPIoM
Regards
mcb58 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to mcb58 For This Useful Post:
DIAGSYSTEM25 (19/02/2019), ElTurco (19/02/2019), vortex (19/02/2019)
Vieux 19/02/2019, 15h39   #2
ElTurco
Avatar de ElTurco
ElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond reputeElTurco has a reputation beyond repute
Selam kardesim, sagol var ol.
Merci frere pour le partage.
"Ne pas faire aux autres ce que l'on ne veux pas que les autres te face"
ElTurco est connecté maintenant   Réponse avec citation
The Following User Says Thank You to ElTurco For This Useful Post:
Vieux 19/02/2019, 18h22   #3
DIAGSYSTEM25
Avatar de DIAGSYSTEM25
Selam kardeslerim bu kirmizi ficilen calisiyormu
Oblinksx?
DIAGSYSTEM25 est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to DIAGSYSTEM25 For This Useful Post:
autodiagauto (19/02/2019), ElTurco (11/06/2019)
Vieux 19/02/2019, 19h07   #4
autodiagauto
Avatar de autodiagauto
autodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond repute
Bonsoir
je donne ma langue au chat
Miaou
autodiagauto est connecté maintenant   Réponse avec citation
The Following 2 Users Say Thank You to autodiagauto For This Useful Post:
DIAGSYSTEM25 (19/02/2019), ElTurco (11/06/2019)
Vieux 19/02/2019, 19h22   #5
DIAGSYSTEM25
Miaou.....
Bref en faites je demandais avec quel interface sa fonctionnais....
Vieux 23/02/2019, 13h35   #6
ElTurco
Avatar de ElTurco
Miaou.....
Salut les amis, frère DIAGSYSTEM25, normalement il faut un câble genre ELM327 avec puce 18F258 + MCP2515 + MCP2551 ... Je possède le ELM327 full chip avec PIC18F2480 et le OBDlink SX (câble rouge USB) je vais essayer et te tiens au courant.
J'ai aussi le ELS27 : vais essayer tout ça, le soft est en plusieurs langues sauf le Français le Turc est présent : impeccable, installer en 5 min et fonctionnel, à voir maintenant pour le bon câble adapté.
Merci encore frère mcb58.
autodiagauto (23/02/2019)
Vieux 24/02/2019, 08h29   #7
ElTurco
Avatar de ElTurco
Salut les amis
Finalement j'ai pas pu essayer parce que la Ford sous la mains n'était plus dispo, en revanche j'ai fait des recherches pour voir s'il est possible d'utiliser Focom avec Elm327, d'après certaines personnes il est possible d'utiliser le ELM pour Focom d'après d'autres personnes il ne fonctionne pas du tout.
Bref je pense que la qualité et les composants présent dans le cable est important pour le bon fonctionnement mais meme si ca fonctionne, ca reste ok pour les défauts générique, pas moyens d'aller plus loi.
D'après la lecture, le Focom possède un Numéro de Série pour le bon fonctionnement du soft, ce numéro est présent dans les cables FOCOM vendu chez les Chinatown, il est similaire au ELM327 mais pas les memes composant et codage surement.
Comme dit plus haut, ce cable (VCM OBD V.2) est au prix d'un bon elm327 USB et possede les puces PIC18F258, MCP2515, MCP2551 et des transistors.
Je n'est pas pu essayer avec le cable OBDLINK SX ni ELS27 desoler, je pense que le mieux serait ce fameux cable.
A+ les frères.
autodiagauto (24/02/2019)
Vieux 24/02/2019, 09h44   #8
adiago
Avatar de adiago
Pouvoir de réputation: 31
il faut l'interface officielle Ficom (secon) et la licence .
adiago est connecté maintenant   Réponse avec citation
ElTurco (24/02/2019)
Vieux 24/02/2019, 11h22   #9
ElTurco
Avatar de ElTurco
Salut les frères
Merci adiago pour le partage, effectivement j'ai fait des recherches sur le câble Ficom ori qui coûte pas trop chère, ils ont même d'autres câbles PSA Com... jusqu'à 2015 ? En tout cas intéressant merci pour l'info frère adiago.
J'ai trouver aussi le vrai full chip du VCM OBD V 2.0, cela ressemble à ça ...
Il y à en plus, les puces 9241A (pour les lignes K L ?) au lieu des transistors, mais sur les adaptateurs chez les chinatown par soucie de bénéf (je pense) les 2 puces on été remplacer par des transistor.
Voilà en gros pour les infos
A+ les frères.
The Following 2 Users Say Thank You to ElTurco For This Useful Post:
adiago (24/02/2019), autodiagauto (24/02/2019)
PSA COM Version 2.5.1.0 26 Avril 2019 zenata Peugeot, Citroën 26 29/07/2020 07h03
ficom karera 1 Vente, Achat, Echange 0 17/03/2020 22h36
les nouveautés manuel atelier 2019 land rover evoque 2019 yacine27000 schémas de câblage, documentation 0 12/11/2019 12h16
logiciel PORSCHE pet2 version 8 10/2019 jeremy72 Autres 0 28/10/2019 14h39
Focom version 1.0.18479, Feb 8 2019 mcb58 FoCOM, Examiner Smart 1 19/02/2019 15h43
Fuseau horaire GMT +1. Il est actuellement 14h07.
